Results 1 to 10 of 15
Thread: Coilovers
    Blantyre
    Default Coilovers
    Simple Yes or No
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    don't have them but a big thumb's up from me mate.......low is the only way to go
    Midlands Mod Shop - NFFC.
    Blantyre
    Can you use your normal springs on the rear or better to uprate them also, bit of a noob on this
    Feb 2006
    Guttedsville
    Big Man is the one to ask this question, he had coilovers on his old SRi.
    Jul 2006
    TBH I think if you had coilovers on the front and no drop at all on the back you'd run a serious risk of looking like a pillock.
    If you're going to do it, why not do it all round? The rears are a doddle to do compared to the fronts.
    Blantyre
    Quote Originally Posted by parapaul View Post
    Damn...... was only going to put the coil overs on front left and rear right
    lol
    My question was, would the kit include all the springs
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Right...
    Coilovers need to be fitted all round, dont bother with anything else.. The car would be dangerously unstable!!!(Alot harder on the front than rear!!)
    The coilover kit should come with...
    2 x Front Coilover Strut Assembly(Spring and Shock as one unit)
    2 x Rear Springs
    2 X Rear Height adjustable platforms
    2 x Rear Shock absorbers
    2 x Height Adjustment keys
    1 x Can of lubrication spray
    If any of the above are missing, i'd walk away...
    Who are they made by out of interest???
    The rears are not a coil over as such, although they are fully height adjustable. Basically you fit the rear shock as per normal, then fit the rear spring as per normal, but where the reasr spring meets the locating bit on the chassis, you put the height adjuster in there, and the just raise/lower it as you see fit..
    Now, when you fit them, you need to decide how low you want the car.. i wanted the car Max Low from the start, so just would the platforms right down from the start, if you dont, make sure you count how many turns you wind the first platform up/down by, and mae sure all four platforms are the same amount of turns down, or it will be uneven..
    HTH
    Blantyre
    FK highsport COILOVER SUSPENSION
    PART NUMBER FKOP60-TO FIT VAUXHALL VECTRA C
    Jun 2007
    Quote Originally Posted by spennny View Post
    Exactly what i had on mine...
    Very good kit.
    Is it Brand New or used??
    Blantyre
    Quote Originally Posted by BigMan View Post
    Very good kit.
    Its brand new m8, watching it on Ebay now, guid price is sitting at £400 - is that reasonable ??
  1. FK coilovers....yay or nay?
    By Jaspa in forum Handling & Braking
    Last Post: 30th November 2012, 14:32
  2. coilovers
    By veccy c in forum Handling & Braking
    Last Post: 27th January 2012, 00:19
  3. FK Coilovers
    By tubby in forum Suspension, Wheels & Brakes
    Last Post: 25th November 2011, 20:05
  4. coilovers
    By ants sri in forum Styling
    Last Post: 29th April 2011, 20:54
  5. coilovers
    By magpie in forum Handling & Braking
    Last Post: 31st October 2010, 11:15
