Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: over boosting? diagnosed please help
    chesterfield
    Default over boosting? diagnosed please help
    had car diagnosed today due to engine management coming on when on bypasses
    diagnostics machine says its over boost
    the car has lost power and surges power at random times rather than smoothly
    can anyone tell me what is the cause of over boost
    cheers
    Given your engine the first thing I'd be doing is checking thoroughly all the boost hoses for any splits. It's a common problem on the 2/0/2.2 DTi. A leak of boost would cause a spike in overboost.
    also, remove and clean the boost sensor..it can get gunged up and give false readings back..
    chesterfield
    where is the bost sensor?
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Quote Originally Posted by chowwie View Post
    Good question ive wanted to know this too?
    chesterfield
    just found out i need to remove the engine cver to see it
    follow the intake air hose from the intercooler to the alloy intake housing under the plastic cover on the front of the engine..the very first electronic sensor is the boost sensor..
    chesterfield
    cheers mate for the help
    chesterfield
    Default over boost continued
    i replaced the boost sensor with a brand new one
    so far engine management light not come on but still power loss
    as mentioned before the turbo does not seem to kick hard unless i hover around a sertain rev by holding pedal quater way then press and it flys?
    if i put foot to floor then it seems to flat spot all the way through rev range but all ok if i hover first?
    hope you understand because its hard to explain
    all pipes checked for leaks etc
    i am now thinking it could be viens in the turbo?
    i have heard it mentioned before but not sure of effects if it was this.
    anyway of testing if its viens?
    cheers for any advice
    chesterfield
    2.2 dci diesel 2002
  1. Fault diagnosed :(
    By thegoldenbullet in forum Engine & Drivetrain
    Last Post: 24th July 2012, 21:10
  2. Boosting Power on a 2.0 DTI
    By cdms811 in forum Diesel Engine related
    Last Post: 25th September 2010, 06:39
  3. been diagnosed with diabetes type 2
    By The Gas Man in forum General Chat
    Last Post: 14th June 2010, 12:20
  4. edition 100 boosting problem?
    By marwen in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 21:56
  5. power steering - diagnosed ???
    By Yetti in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2009, 20:49
