Results 1 to 10 of 18
Thread: does my car have traction control?????
    Regular Member dannydm1's Avatar
    Jan 2008
    leeds / wakefield
    Default does my car have traction control?????
    hi all, i have a vectra sri on a 03 plate, i have been told that i can put in a traction control switch ander the alarm button and it will work??
    is this true?? if so why wasnt it fitted with the switch when it was made??
    Regular Member Robbie69's Avatar
    I think it's just a case of but a switch and see, some work and some don't mate, pot luck!
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If you look behind that blank switch there should be wires if there is its a 50/50 chance it will work,just buy a switch and try
    Belfast
    Surely the TC switch turns the TC off, same as the Astra? Fitting a switch won't suddenly give your car traction control.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    the switch is for turning TC OFF (under 40mph) and is 50/50 as to whether it will work (mine doesn't - but lights up at night!)
    When you turn the ignition on, do you see an orange skidding car light for a few seconds? If so you have TC and a switch MIGHT let you turn it off.
    Devon
    53 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by LJ sxi-nav View Post
    If you dont have the orange skidding car light then you dont have tc and no matter what switch you put in there it wont work,all though you have an sri i thought it was pretty much standard on pre face lifts i might be wrong
    Regular Member cameraman's Avatar
    Leicester
    Depends on the engine & the switch will only turn it off (if it works)
    Regular Member Karl's Avatar
    Sunderland
    good chance it has tc. Best way to tell is to boot it round a roundabout and loose traction, if a little skidding car comes on the dash, then you have tc.
    Whether the switch works though, it appears to be hit and miss
    Sunny Dartmoor
    Its pot luck if it'll work or not......
    Sunny Dartmoor
    If its a 1.8 then it won't have it,as it wasn't fitted to them.......
  1. my traction control how to
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2012, 20:01
  2. traction control
    By ggg1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2009, 18:07
  3. 2.0T Traction Control
    By kryton01 in forum Engine & Drivetrain
    Last Post: 20th October 2009, 17:18
  4. traction control
    By jsnlvxr in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 21:56
  5. traction control
    By jamesv6 in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2006, 00:13
does my vectra c 2008 1.8 engine have tc
