Thread: brake failure ????????????
    cheshire
    Default brake failure ????????????
    Hi all hoping I can get some help I have vectra 2.0l diesel. I have changed the rear brake pads a few times, but this time I have lost pedal I can pump it and get it quite hard ( no puns intended) without the engine running,
    my drive is on a slope and this will stop the car moving. When I start the engine the pedal goes completely until it is pumped again then it will hold the car but once you take your foot off the pedal and go back to it seconds later then no pedal again straight to floor with no brake effort hellppp!!!!!!!!!! (the hand brake holds the car fine ??????)
    that sounds like a master cylinder or servo fault...erring towards a servo, if the m/c pumps up soild in no more than 2 pumps..
    cheshire
    thanks got a master fit tech support coming out today to have a look and possibly change fluid see how that goes
    cheshire
    Default sorted
    bleed and new brake fluid seems to have solved problem
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. Brake pedal creep - 2.0T - MOT failure!
    By Gus93 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th June 2012, 20:40
  4. Brake bulb failure flashes and then goes away
    Last Post: 7th March 2012, 22:09
  5. Brake Pipes....MOT failure
    By Stevie-B in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2007, 12:54
