Results 1 to 10 of 16
Thread: Spanner light and slight loss of power 2.2dti
    Regular Member nickd_m's Avatar
    Ely, Cambs
    Default Spanner light and slight loss of power 2.2dti
    Hi all,
    I have a 2.2dti and the spanner light has just come on the dash board. It did say 1000 under but this has now disapeared. It is only on when you turn the ignition on and turns off once started.
    I assumed this meant i needed a service but I only had one 3 months ago - about 6000miles. Maybe i need an oil change?
    The other thing i have noticed is that in the mornings it takes a little longer for the engine to kick in, plus i seem a bit slower pulling away now.
    Im thinking maybe spark plugs?
    If this is all the case il take a trip back to the garage as the oil and plugs should have been changed at the service.
    Any help would be great, cheers
    first off, there are no sparkplugs on the DTi's.. just glow plugs and as it starts okay then i'd rule them out.. ( they're not service items BTW)...
    without plugging it in to a code reader to know for sure whats wrong with it, popular 'faults' on the DTi are gunged up boost sensor, sooted up EGR valve...
    for my money it sounds like you have an issue with their of those..
    chesterfield
    mine exact same engine mate and same problem and is showing over boost on diagnostics
    Ely, Cambs
    Thanks a lot.
    Sorry I did know that - re: spark/glow plugs - just having a funny five minutes :-)
    Do you no how I would go about cleaning out both the boost sensor and EGR valve or is it really a "garage job" ?
    thanks again
    chesterfield
    Quote Originally Posted by nickd_m View Post
    Thanks a lot.
    thanks again
    egr valve located front of engine and simple to do
    there is a how to thread in the how to section mate
    boost sensor i believe is to the right of engine with a few pipes running off it and one pipe runs direct to back of turbo area
    wd40 seems to be peoples favoruite for boost sensor mate
    hope this helps
    boost sensor is actually the very first sensor on the air intake to the engine from the intercooler.. it's secured by one torx screw and has one electrical plug running to it..clean it with brake cleaner or the like..it should be brassy in colour but i bet your's is black..
    Nottingham
    this forum is ****** useful! thanks guys.
    I've got the same issue on my 2.0DTi so will try these two things and report back. It's my commuter so i need it back to health this weekend (doing my 150 mile round trip commute in my S2000 today)..
    are the ODBII readers on ebay useful?
    early ( pre 2004) diesels are hit and mis.. mainly miss on anything below about £100.... they make big claims but often have only a shallow scanning ability..
    Nottingham
    my car is an 04.. gonna try your 2 tweaks and see how she goes. otherwise off to the local garage
    Nottingham
    well, cleaned those two and cel gone. fantastic. we'll see if it lasts.
    the EGR was filthy and the other one i took off the piece of the inlet it was bolted to and that was gunked up to hell... took me ages to clean it
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Spanner light & loss of power
    By kamar in forum Vectra C / Signum Troubleshooting
    Last Post: 9th January 2013, 23:10
  3. 1.9 cdti spanner light power loss
    By elite itchy in forum Engine & Drivetrain
    Last Post: 16th June 2010, 23:25
  4. Spanner light on but no loss of power
    By jonesy1 in forum Engine & Drivetrain
    Last Post: 1st May 2010, 12:58
  5. Loss of power and spanner light!
    By martinhill in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 18:48
2.2 dti vectra spanner light no power
vectra 2.2 dti spanner power loss
vectra c 2.2dti..oil can with spanner through it
vectra c 2.2dti engine light coming on in 1st and second
