Thread: Water in boot of Hatchback
    Oct 2007
    LONDON
    Default Water in boot of Hatchback
    Appears to be getting in around where the rubber seal and flexible covering is to protect wiring to high level stop light. Have put some mastic over the seal and appears to have solved the problem, although did find some water in the boot recently. Can anyone recommend a good mastic and how easy is it to replace this seal and wiring cover
    the seal comes with the lamp.... do you have a little lip spoiler on the outside of your bootlid?.. or is it a life/LS/Elite?..
    i've done several SXi/SRi/GSi now where the bootlid fills with water, and it's turned out to be poor sealing of the bootlip spoiler..
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    This thread might also give some pointers incase its getting in from somewhere else.
    Oct 2007
    LONDON
    Thanks for the info and other links. No tail lip. Water gathers in N/S beneath the rear light. Had to have some body repair done to rear bumper and repairers noticed water but they said not related to rear damage. They said it came from the area I described as this "gaiter" had split due to wear. They put a load of mastic around it which appeared to do the job, until recently. I've also put mastic sealant on but still getting damp. I don't think the seal around the light cluster has perished since have been driving in a lot of rain. So, still think it's this gaiter. I suppose I'll just have to take all the inner trim out, because the link is behind the trim, and hose the car down.
  1. Replies: 4
    Last Post: 5th October 2011, 19:31
  2. 04 hatchback boot slipped
    By pitsmoor21 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2008, 23:52
  3. hatchback water problem?
    By pyro_maniac in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2007, 15:30
  4. Hatchback boot won't open!
    By vectravirg in forum Bodywork & Interior
    Last Post: 4th February 2007, 12:10
