Thread: respraying bumper
    kirriemuir
    Eek respraying bumper
    i,ve got the paint from paint for u quiet a good match 2 pak silver lighting, i,ve done the lower part but have a slight bloom on it,is it possible to polish the bloom out or will i have to do it again ? reversing out of the work car park at the same time as a workmate both blind sided
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    In the past I have painted cars and when the paint as bloomed I have polished it out but I always used Cellulose paint. Maybe you could try really fine wet'n'dry paper with soapy water 1200grit or higher.
    kirriemuir
    i,ve got g3 that was sent with the kit so i,ll sand it with 1200 as you say and try some g3 on top of that
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by slugo View Post
    not a good time of year to paint my friend ...you really need a heated garage or such like ..think i would do it again in warmer conditions.. you could spray it again but the chances are it will bloom again
    kirriemuir
    i do have heat the problem today was my motorbikes in there aswell and i forgot the keys to move it to let me get the door shut. next time i,ll move the bike first and heat the garage up first.do you think i would be better covering it up the next time before i leave as i can,t leave the heat on all night ?
    Edinburgh/outskirts
    Mileage : 38000
    Its not just the heat, at this time of year there is so much moisture in the air and cold that is what give you the blooming ..you really need it dry,warm constant, which is not to easy at this time of year.. i have a few spray jobs to do myself but i will not tackle them till warmer weather is here ... no doubt someone will have a different oppinion ...but in the years i have been painting cars thats what i have found ..hope it help you
    rgds Phil
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    to be honest i would try some 1500grit rather than the 1200 or even 1800grit if u can get it,like phil says there is so much moisture in the air that this time of the year isn't the best for the job especially when you come to lacque then u will have seriouse probs.
    kirriemuir
    i had 1200 grit gave it a wee rub applyed g3 rub it down looks really good i know its the wrong time of year but seeing the car looking like that is depressing. the coluor match is perfect with the rest
  1. Respraying - bumpers!!
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 7th June 2012, 08:42
  2. Respraying my splitter
    By rockafella8587 in forum Detailing and Car Care Discussion
    Last Post: 15th May 2012, 17:22
  3. Replies: 3
    Last Post: 24th May 2010, 12:45
  4. respraying /claying cars
    By bobssignum in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 11:21
  5. General question on respraying
    By Ste in forum General Chat
    Last Post: 12th January 2008, 18:16
