Results 1 to 10 of 18
Thread: Steering Control Module
    Liverpool
    Default Steering Control Module
    My speedo has been blimping sevral times then eventually shutting off along with the temp and petrol gauges. When stopped and re-started the whole cycle starts again!
    My local garage has advised a new steering control module. Assuming this will solve the prob, im trying to get hold of a second hand one as thay are £300 from vaux.
    I understand they need to be tech2 decoded from the donor car and then re-coded to mine. Is this correct? My local scrappy has one (not decoded from the donor car) but not sure it will work?
    Any ideas or names of second hand part suppliers that could assist with supplying a decoded module?
    Chris
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    yes they need to be reset from the car then removed then reprogramed to the car when fitted
    might be easyer to bite the bullet and go for a new one
    Northampton
    Engine : A20DTH
    Mileage : 88000
    try www.airbagsforsale.com
    they will need the iDent code from yours which means you have to take the steering wheel off. It will be a something like XU
    Liverpool
    Just tried airbagsforsale.com surprisingly they only deal with airbags and associated ecu's! Any other sources i could try?????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Strange that a I got one from them a while back, do you know the iDent code yet?
    Whats the year, model, trim level ie SRi and I will see what I can do
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    First off mate, unplug the large ABS plug and give it a squirt with WD 40. The poor plug contacts cause the same symptoms. Mine would do exactly the same until I got the WD 40 on it. If its still doing it after then you haven't lost anything.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Try using switch cleaner as it will not leave residue and will clean the contacts better as well (get it from maplins)
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by chrisd View Post
    ... and steering wheels if you ask.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by merikiito View Post
    Never knew that, cheers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Also WD40 is so one little electrical spark and ...................
  1. control unit steering column module fuse burning out !!! Please help
    By fedehernan in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 21:37
  2. Body Control Module
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2009, 17:50
  3. GSI Body Control Module?
    By 900ss in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2009, 08:56
  4. Steering wheel Control Module Question...
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2008, 00:35
  5. Steering Control Module
    By spoons in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2008, 21:50
