Thread: Driver side wiper stops at ~70 degrees
    Riga, Latvia
    Default Driver side wiper stops at ~70 degrees
    Hello, i have this problem:
    My driver's side windscreen wiper doesn't slide to the 90 degree position, but stops somewhere at 70 degrees. This really annoys me in the rainy days. Is it something with me wiper motor? I really hope i can fix it by myself.
    My car is 2003 Signum v6 3.0dti.
    Here's the picture how it looks like when it's on it's top position:
    Attachment 13510
    Thank you!
    Darlington
    Mine did the same last night. Popped into dealer amd they replaced the motor. Furtunately warranty covered the repair.
    Riga, Latvia
    Too bad i don't have any warranty.
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    how about undoing the 13mm nut at the bottom of the arm and moving it up a little, mine was also like that and it hit the other wiper at the bottom when going fast
    Bradford
    Trim : Elite Auto
    Engine : 2.2 Direct Petrol
    Could a few others please confirm if the wiper is supposed to wipe all the way to the edge (ie at the 90 degree angle).
    My Vectra also stops at the 70 degree angle (which i thought was a bit daft) - i was assuming they were all like that??
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Mine wipes right back to the vertical point, and maybe a fraction over vertical but only a touch.
    I assume they still use a splined shaft so its unlikely to have moved on the shaft.
    Regular Member scoobs's Avatar
    Leicestershire in the sticks!
    Mine wipes to vertical too. Sounds like a wiper linkage issue to me.
    Regular Member stuee's Avatar
    witney near oxford ish
    have you had the w/screen replaced or taken the wipers of mate??
    Riga, Latvia
    i will try. thanks
  1. Drivers side indicator light stops on?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 21:44
  2. Driver Side Fog Lamp
    By spennny in forum Parts for sale
    Last Post: 10th February 2009, 17:59
  3. How to fit a driver side wing
    By 111 in forum Bodywork & Interior
    Last Post: 20th October 2006, 17:18
