Results 1 to 10 of 13
Thread: Suspension change - now a knocking noise
    Regular Member danlat1415's Avatar
    Lancashire
    Default Suspension change - now a knocking noise
    Hi guys,
    I've finally managed to change my suspension over to the Eibach springs and Bilstein B4 shocks.
    Just finished it tonight, and took the car out for a spin.
    It was fine for 3 streets, then when I was going round a mini roundabout, I heard a noise on the passenger side front. Just off the roundabout was some speed bumps (i'd gone this way on purpose to test the suspension). When I went over the first couple of speed bumps, there were weird noises coming from the front passenger side.
    It sounded like something was about to fall off somewhere...
    I pulled the car in, and double checked everything, Nothing was loose, nothing had been missed off. I did notice that the front was lower than it used to, and it may be that the wheel is touching the wheel arch when I turn corners or go over speed bumps.
    I've never had the wheel touch the wheelarch before, so I'm not sure on what it sounds like, but thats the only think I can think of it being.
    Can anyone suggest anything, or has had this problem before?
    I've got 18 low profile wheels, if you need to know that..
    Dan
    Tyneside
    Top strut bearings possibly. I changed my suspension, lowered springs and Bilstein dampers and the extra stress brought out the noise in the bearings which were goosed. Noise mainly came when turning the steering
    Lancashire
    Quote Originally Posted by mark1319 View Post
    What are them then, and does that mean I need to change them too?
    missis is not going to be happy...
    Tyneside
    They're cheap mate, think it was about £18 at trade. Only problem is the suspension has to be taken apart agin
    When you had them apart you'll have noticed the plastic part at the top of the strut that spins to allow for movement when steering. It goes between the spring an the plate.
    Tyneside
    Used your pic to try and show you. Of course I can't say for sure it is this, but it is very prominent when turning the steering.
    The only way to know is to change them over as you can't check them when they're off the car unless you can replicate all the forces the car puts on them. I thought mine were fine because there was no noise when turning them, but they had no weight against them at all, even standing on them they sounded fine. Sorry to babble on LOL.
    Lancashire
    No thats fine, very helpful!
    I did just swap over the old ones because I didn't get any new ones, just new springs and struts.
    Do you know the part number for it?
    Is the car safe to drive until I get chance to replace at the weekend?
    Tyneside
    Yep will be safe to drive, just a pain in the ar$e noise to put up with.
    The Part No:13270705 £15.20+Vat each.
    Lancashire
    Thanks, you're a star.
    I'll order 1 or 2 tomorrow.
    I'm just annoyed I've go to go through taking it apart again. It was such a pain in the ..... last time.
    Oh well. Only way of knowing if thats it, is to change it.
    Tyneside
    Have you got the sleeves on the bottom of the spring as well? And some grease in the spring seat? That's the only other things I can think of it being.
    Lancashire
    Yhe i've got the spring mods and a bit of copper grease on the bottom of spring.
    I'll order them tomorrow, and see how it goes.
  1. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  2. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  3. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  4. Rear suspension knocking noise, help
    By clive3373 in forum General Chat
    Last Post: 8th May 2009, 20:24
  5. Knocking Noise from Suspension
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2008, 13:22
