Results 1 to 10 of 13
Thread: Headlight alignment and VX dealer trouble
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Headlight alignment and VX dealer trouble
    Right put in my VX Xenons in the other week and dropped the car off to get the headlights aligned at VX and get the handbrake recall done at the same time.
    Told them to check that the headlights were set for RHD as they were new when I got them from rorycarz on the forum. If they had any problems told them to call me.
    Anyways called me and told me all done.
    First night out in the dark and.....................
    Yep set for LHD! T it s
    Headligts set so low they would not light up a cars number plate in front of me.
    so back to VX today to get them to check them. Stood over them while they tested them. They decide they are not right but dont know why. So I ended up taking the back cover off the full beams and adjusting the lever myself to change them to RHD. VX lads say "never knew you could do that". "That explains why the beam is a strange pattern then" says the guy who did the alignment the first time round
    So he adjusts the headlights up to the maximum that he can and off I go only to realise half way down the road that..........
    I have just paid for a job that I did mostly myself! Time for a refund I think when I am passing next
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by merikiito View Post
    I've seen a few threads thats mentioned the change over lever for the lights conversion RHD/LHD.
    Am I correct in assuming the changeover levers were only fitted on earlier models. IOW the new facelift vec-c' dont have them do they???
    Would be great for me if they did, but cant say I noticed anything like a lever when I replaced all the front bulbs recently.
    Sunny Dartmoor
    Glad you got them done Lee,but have to agree,you did most of the work and they found out how to do something that you showed them,they should've paid you.........
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ok just been out and checked my orginal SRi headlights and there is no sign of a lever in them. It seems it must only be in the VX Xenons that there is a lever. I do know that the copies of the SRi lights (Depo ones) have some sort of lever as I had these on my old Vectra C Saloon which are now on Bigmacs car via his brothers car lol. This only applies to the Pre Facelift versions, i have no idea about the facelift lights.
    Feb 2006
    Guttedsville
    My old pre facelift SRi certainly had levers in the lights.
    Had it down to a fine art!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    wish they had them in the facelift ones
    North Wales / Leeds / South France
    any pics of where this lever can be found as i go to france quite often
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    My 04 LS has them too. Works a treat on the car park waiting for the chunnel.
    Quote Originally Posted by Cameron43 View Post
    IIOW the new facelift vec-c' dont have them do they???
    Nope. Only if you have Xenons can you do a LHD/RHD switchover by adjusting a fuse position, or with AFL you do it through a procedure on the indicator stalk.
    Not just Xenons, the levers are on the bog-standard Halogen lights as well.
    Quote Originally Posted by phil0464 View Post
    http://forum.vectra-c.com/showthread...ver#post359179
    Apr 2008
    In UK
    Shame they are not on the Vec C facelifts, would have saved me a load of hasstle as I'm over there quite often.
    The stick-on EuroLites tend to leave a right mess behind when you remove them, so what I do now is to re-use the same ones rather than keep buying a new set everytime I go over.
    All the original glue has now gone from mine, but you can buy packs of clear silicone gel glue dabs, which look like those glue gel dabs that hold the Aluminum Tax disc mounts to the windsreen, they are like a tacky clear gel, I just put a couple of those Gel dabs on the Eurolites and they do the job brilliantly, and they come of cleanly too with no damage to the plastic lens. Also good as replacement gel pads for the tax disc holder of course. Most stationers will sell them.
    A bit like clear bluetac.
  1. Headlight Alignment
    By 12345 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2012, 20:11
  2. Headlight Alignment
    By maurauth in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2009, 17:16
  3. headlight alignment
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2007, 17:14
  4. Headlight Alignment help needed?
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 15:58
  5. Headlight alignment
    By The Gas Man in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2006, 18:50
