Thread: burst spring clutch PROBLEM
    Default burst spring clutch PROBLEM
    hello I Have a problem because burst spring clutch and I don't know whether this will be good I have Vectra C 1.8 Nr.: 90 06 348
    that looks very much like the retrofit clutch spring kit.. it should work fine..
    PL:
    Tylko czy jak ją założyć? Gdzie ta co pekła ma inny kształt! mozesz powiedziec czy albo dac foto twojego pedała?
    ENG:
    If only to set it up as? Where is the burst has a different shape! You can tell whether or give your photo pedal?
    I can't take a photo of my pedal as mine is an automatic, but that is a replacement part made to fit in a different part of the clutch pedal.. not in the place of the original spring..
  1. Clutch spring mod...
    Last Post: 24th November 2015, 17:28
  2. Clutch Spring
    By Ian T in forum Bodywork & Interior
    Last Post: 19th November 2014, 01:19
  3. Clutch spring kit
    By KEV E in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 17:02
  4. Clutch Spring
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 15:39
  5. New Clutch Spring
    By Vec-6289 in forum Engine & Drivetrain
    Last Post: 29th September 2007, 19:30
vectra clutch assembly spring
