Thread: Engine Fault Code
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Engine Fault Code
    Hope someone can help on this one. got myself a code reader due to EML light coming on then off then on and so on. Scan is coming up with fault P0170-Fuel trim malfunction(bank 1). Anyone who can shine a light to what this means.
    you need to replace the lambda sensor..it can't regulate the engines mixture.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you check the lambda (oxygen) sensor operation with your kit?
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    cant test seperate equipment only reads the fault code stored in the ECU and allows a simple erase/reset to be carried out. Dont mind this as kit only cost £25 and cheaper than stealers to look at also can use on any make of car so handy for hobbles £10 diagnose/reset charge
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    could be air flow meter
  1. For Sale: D900 Any OBD2 EOBD CAN BUS Car Engine Fault Code Reader
    By david-bell in forum General items for sale
    Last Post: 25th January 2013, 23:42
  2. Replies: 2
    Last Post: 10th September 2012, 19:09
  3. Fault code help :(
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 4th February 2012, 20:14
  4. engine fault code po305
    By gspot10 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2010, 12:37
  5. Engine fault code reset
    By papz in forum Troubleshooting
    Last Post: 21st June 2009, 18:44
