Thread: Under-powered Direct.....
    Larkhall
    Default Under-powered Direct.....
    Small query for you lot.......
    Since getting the car 10 weeks ago the performance seems to be getting worse. I've done 3000 miles since then and lately i've noticed that flooring it makes very little difference to the speed i'm doing.
    The first couple of days were brilliant - i could tap the accelerator while doing 80 and it would shoot off - now it struggles to reach 40 without me literally having to put the foot to the floor.
    I've done an oil and filter change using GM spec 5W30 and obviously the plug change. I also filled up with V-power for the first time last week.
    Is there anything you guys can suggest to get it back to it's peak performance as i'm quite upset at how under-powered it seems........
    SCOTLAND
    long shot as i know he haw about mechanics but did you say you had done an engine flush on it, might be problem with oil sprayers clogging.
    I dont know just i was advised against doing a flush on the same engine
    Regular Member EURO G's Avatar
    n ireland
    maybe an airflow meter problem car getting less air would make it very unresponsive
    Tyneside
    Did you go ahead and get the engine flush Tam?
    Larkhall
    Quote Originally Posted by mark1319 View Post
    Aye Mark. Left the car with the mechanic and when i went back he said he'd done it......
    Is there any way to clear the jets if they are clogged?
    Tyneside
    Not sure mate, but I wouldn't be surprised if it has caused some ill effects.
  1. powered boot lid
    By Siggy08 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2012, 17:24
  2. Steam Powered (PC Gamers)
    By Gazz in forum Games Room
    Last Post: 14th August 2011, 12:57
  3. powered tailgate problems
    By a wood in forum Bodywork & Interior
    Last Post: 22nd October 2010, 13:11
  4. Solar powered Dog ???
    By soulman in forum General Chat
    Last Post: 8th October 2007, 00:12
  5. new powered sub
    By Beavis in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2006, 14:42
