Results 1 to 10 of 13
Thread: Vectra 1.9 CDTi (150) - engine rattle
    Lancashire
    Default Vectra 1.9 CDTi (150) - engine rattle
    I have just bought thie car from new having had a VW Passat Diesel. The Vectra is very impresive, and also very quiet on the motoway etc. However, around town at low speeds, especially under light acceleartion it sounds like a tractor.
    I drove the salesmans car to check, and whilst it too was a little noisy, it was nowhere near as loud as mine. The problem only ocurs once the car is warm. From cold, until it warms up, there is no problem at all.
    Has anyone else noticed this?
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Was the salesman's car a higher spec model? If so, it could have had more soundproofing. In my limited experience they get quieter when warmed up, not noisier.
    It could of course be an illusion, due to the general quietness of everything else in the car (wind, suspension, tyres)...possibly?
    Doug
    Lancashire
    Doug - yes it was higher spec, but I dont think that explains it. The VW was very quiet at all speeds, and that might explain things. However, like you, I would expect the car to be quieter once warm. Not the other way round.
    Regular Member ion's Avatar
    walsall
    They are a bit rattley at low speed, 1st & 2nd gear. The salesman's car might have more miles on it as well so might be "loosened up" more?
    I've got 17000 on mine & it seems quieter over the last 2000 or so.
    walsall
    I test drove a Passat though & it was about the same at low speed, & noisier when on the move.
    Thats a part of why I chose the vec.
    Regular Member Ian's Avatar
    York
    mines done 8500 miles from new and its deadly quiet when warmed up, to the point when you can hardly here it in the cabin. its a little noisey when cold though (obviously opposite to srcrossley).
    Lancashire
    Thanks for all your comments. Been out in it again today, and it is definitely worse when warm - only in low gears though around town when accelerating gently. I'm taking it back to the dealer at the end of the week for checking. Its almost as if there is a problem with the fuel mixture/timing - possibly the knock sensor or something.
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    Let us know if they find anything wrong - it's worth knowing about if it starts to afflict one of us too!
    Hope they get it sorted for you.
    Lancashire
    Had it checked today and apparrently the sound is 'normal'. It happens when you 'take up' speed from a standing start until the turbo kicks in. I have now driven three cars (2 from the garage, and one which was a colleagues hire car) and they do all seem to do it. I think mines worse because I paid for it though!
    That said, under normal conditions on the open road, or above 30mph at a constant speed, its as quiet as a mouse.
    Lancashire
    Update - nature of my job involves around 1000 miles per week. Engine rattle has almost completely gone. Possibly therefore, it is just a case of loosening up, the more miles that you do. Good car, first Vauxhall - and overall very impressed for the price I paid.
  1. 1.9 CDTI 150 Rattle at engine stop
    By dariousa in forum Engine & Drivetrain
    Last Post: 12th September 2012, 10:24
  2. Replies: 35
    Last Post: 5th May 2012, 15:32
  3. Engine rattle vectra 150 cdti.
    By sla002 in forum Engine & Drivetrain
    Last Post: 4th August 2011, 17:40
  4. engine rattle on 150 cdti
    By lops01 in forum Engine & Drivetrain
    Last Post: 23rd July 2010, 08:22
  5. 1.9 CDTi engine rattle
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2007, 19:25
vectra cdti 150 engine rattle
