Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Pc to TV
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Pc to TV
    just downloaded a few tv programmes from iplayer..and instead of watching them on the pc, was wondering if there was anything i need to hook the pc up to the tv instead..
    have got the connections on the back of the tv..is it just a matter of plugging the monitor cable into the back of the tv??.. or is there anything else i need to do?..
    N.Wales
    if you have VGA in on your TV then your sorted.
    just plug it in and away you go - depending on your graphics card it will auto adjust to the best settings so you won't have to do anything at all - for example my ATI Radeon recognises my Samsung 42" and adjusts accordingly, even sets the correct refresh rate etc etc.
    speaking on which i've just had delivered today a DVI to HDMI connector so i can output 1080 video from my PC to TV
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Doesn't your computer have a HDMI outlet?? If so, just buy a cable for about a fiver from wilko's. Or a bit more from gold plated terminals or longer leads.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    If your TV has HDMI or DVI inputs, and your PC has a DVI port then you can link them using a DVI cable (or in the case of your TV having HDMI a DVI to HDMI cable).
    [Ex]Admin Duncan's Avatar
    Slight hijack....
    Quote Originally Posted by Phatty View Post
    My plasma TV has that and that's how I currently connect the laptop to the plasma screen....
    ....speaking on which i've just had delivered today a DVI to HDMI connector so i can output 1080 video from my PC to TV
    ...but the docking station that the laptop sits in when it's in the AV rack also has a DVI output, so would I benefit from a DVI to HDMI cable or will I not see any/much difference over the VGA connection?
    N.Wales
    if i'm right chaps Dwabo is just talking about a standard VGA 15pin D-Sub connector...
    it was me that got on to the DVI topic sorry
    N.Wales
    Slight hijack....
    My plasma TV has that and that's how I currently connect the laptop to the plasma screen.......but the docking station that the laptop sits in when it's in the AV rack also has a DVI output, so would I benefit from a DVI to HDMI cable or will I not see any/much difference over the VGA connection?
    depends really...
    my setup only supports 1024x768 over VGA but increased resolution over DVI so thats why i'm switching.
    For everyday use then VGA is fine, but if your looking to use it to play video's (HTPC) or gaming then i'd switch to DVI.
    VGA is analog where DVI is digital so it works differently...
    quote from Wiki:
    The DVI interface uses a digital protocol in which the desired illumination of pixels is transmitted as binary data. When the display is driven at its native resolution, it will read each number and apply that brightness to the appropriate pixel. In this way, each pixel in the output buffer of the source device corresponds directly to one pixel in the display device, whereas with an analog signal the appearance of each pixel may be affected by its adjacent pixels as well as by electrical noise and other forms of analog distortion.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    For those of you like me who don't have an additional VGA or a DVI output from your PC, then you can use a Scan converter such as AverKey100 Pro which sits between the PC and the monitor, and has video RCA jack and s-vhs sockets to connect to your TV. Not as good as a dedicated digital connection but it works.
    Regular Member ccsnet's Avatar
    The local dealers if driving my old Vectra
    Have a look at Keene Electronics who have connectors for just about any thing to anything.... also CPC.co.uk ( who are supplied by KE )..... I've used both in the past with no problems.
    Terran
    ... fell at the first really...
    it wont connect to the tv for some reason..
    any ideas??..
    connected with the d-sub connector from the back of the pc to the tv.. but it wont come on?..
    what else do i need to make it work??..help.. please!
packard bell imedia 1518 pwc plug
