Thread: Washer jets....
    Regular Member mc_orion's Avatar
    Aug 2007
    Worcester...and most motorways!
    Default Washer jets....
    Mine seem to take ages to pump the liquid/water up to the screen for some reason....
    Ive only just noticed this, so anyome else have the same problem or is it just a quirk of the veccy's?
    Sunny Dartmoor
    Probably have a blocked pump,read about it on here a few time's,strip it out and clean pump,hose's and tank.........
    Should be fairly instantaneous mate....
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes mine instant too. As said, there are a few threads on here, the answer is strip bottle out and clean.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Non return valve defective if you get a good jet of water eventually.
    Regular Member s0501291's Avatar
    Warrington
    I had a similar problem. I changed the pump, cleaned out the mesh filter, and still no joy. Turned out to be a blockage in the T-piece of the jets. took both jets out, removed the pipe from each end of them and then pushed a small nale through to clear them. Works perfectly now. But on yours could be just the little mesh filter on the bottle, best to check the easy stuff first
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Agree with ste, if you're gettting good flow eventually. If the flow is poor then think blockage. With duff non-return valve (or a leak) fluid flows back down the tubes and it takes time to re-fill before it comes out of the jet. Had this in a previous car and fitted a new valve in the pipework.
  1. Washer Jets
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 17:20
  2. washer jets
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 19:32
  3. Washer Jets
    By VikBee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 09:06
  4. Are there any better washer jets out there..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:45
