Results 1 to 3 of 3
Thread: engine electronics warning light
    Regular Member ChrisB's Avatar
    Nov 2007
    Bristol
    Default engine electronics warning light
    Has anyone come across this one?i have a vectra 1.9cdti 150, towing the caravan down to devon pefectly ok,next day the engine electronics warning light kept coming on,on overrun and when you put your foot down it went out,there is no performance loss,and nothing seems out of order.is there a vacuum switch that fails on these engines?The car has to go in for the handbrake recall,but i just wondered if anyone had the same fault so as i could fix it before getting an expensive bill.thanks,Chris
    Regular Member Ian G's Avatar
    Merseyside
    You need to read the fault code to be sure. Sounds vacuum/air related.
    Nov 2007
    Bristol
    Thanks for your reply ian,put it on our fault reader where i work but it would not pick up anything(audi/vw)went down the road to a mate in a local garage with a fault readerthat would do almost anything on the market and it came up with the fault.fuel temperature sender,which is fitted in the body of the fuel filter and it's a common fault.by the way the warning light is on all the time now.So i'm off to the local dealer tomorrow to get one,let you know how i get on
  1. Engine electronics light on
    By Steve Day in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2010, 17:16
  2. Engine Electronics light comes on
    By mattaus in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2010, 13:19
  3. Engine electronics warning light
    By Simmo81 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2010, 21:13
  4. Engine electronics light on....
    By Stevie-B in forum Engine & Drivetrain
    Last Post: 16th December 2008, 14:54
  5. Engine Electronics Warning Light
    By petersaxon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2008, 21:29
vauxhall vectra c engine electronics warning light
