Results 1 to 10 of 13
Thread: tyre pressure monitor
    Wolverhampton
    Default tyre pressure monitor
    can the tyre pressure monitor system be retrofitted to an 08 plate astra VXR?
    thanks
    martyn
    Full Member Big Sig's Avatar
    I'm gonna say yes as long as it was a factory option. Just a matter of getting the harnesses, sensors etc tech'2d and it should all be working. You do need to make sure all the electronics for the ecu's are all present or it will mean a whole lot of work for you
    Wolverhampton
    thats the thing, acording to the price guide it was never an option.
    Would prove to be difficult then, was it an option in any country?
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    no tpms was never an option or fitted to facelifts for the uk but was
    overseas only,i was the first to retro fit on me signum using vxl genuine
    parts,its very easy to fit and tech2 if ya know wot ya doing that is
    it was an option on the very earlier pre-facelifts as drinky has it fitted on his
    52 reg elite vectra although on the later pre facelifts it was dropped off the
    option list.
    on certain models you may still find that the wiring may be in place as i had
    on me signum.
    Wolverhampton
    is there anything i can see to know if the loom is in place without taking the car to bits lol?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by vxrmartyn View Post
    well yeah if you look on the drivers side behind the rear lamp trim there
    you may find a leverlock plug with approx 10 wires on it,it may be wrapped
    in a foam pad,another way is that if you have afl then theres a good chance
    you will have the plug behind the arch liner on the front passenger side in
    were the side repeater loom is,if you have these then you will only have to
    replace the rear axle harness to give you the rear reciever plug or can do it
    by repair kit which you make up yourself going by wiring diagrams that ive
    done for few ppl in the past,or making the relevant wiring harness to wire up
    the whole tpms system which is pretty easy if you know wot to do.
    Would it be the same on an astra though Andy?
    Wolverhampton
    i have the AFL option on my car
    12 Post(s)
    Trim : elite
    Year : 2011
    its sort of similar setup for the astra h and corsa d,its called dds (deflation
    detection system) it works through the abs system rather having sensor
    recievers on the body,if anyone requires more info on the dds option then
    let me know as again the dds aint available as an option in the uk but only
    overseas.
  1. Tyre pressure monitor
    By thefibreguy in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2011, 21:33
  2. Tyre Pressure Monitor
    By Veccy159 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 00:21
  3. Tyre Pressure Monitor
    By bigcarman79 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 23:45
  4. Tyre Pressure Monitor
    By ace in forum Vectra C / Signum Troubleshooting
    Last Post: 1st January 2008, 03:42
