Results 1 to 10 of 13
Thread: Nokia ck7w - astra 05 to vectra 04
    Sutton Coldfield
    Default Nokia ck7w - astra 05 to vectra 04
    Hello all
    just bought a nokia ck7w bluetooth kit with a "vauxhall loom". gent says he took it out of an astra 05.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=160291033092
    Will It slot straight into the back of my cdr2005 in my pre-facelift veccy? I did have an old CAARK-91 i took out, and know i can reuse the microphone... I'm a novice with car audio, but happy to get stuck in.
    any advice is welcome!
    Regular Member D4M0's Avatar
    May 2008
    wigan
    ya it should plug straight in mine is an o5 and has the "quad lock" connection the only thing is you will prob av to find an ignition live which you can find behind the glove box at the bk of the use box a thick purple i think its best to check though! i put a ck-7w in mine but hard wired it using the audio outs on the bk of the radio
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    You shouldn't have a problem - as you have a CDR2005 you'll be half-canbus, and as you've already taken out a CARK-91 you should have the VDA plug behind the glovebox on the right hand side, this provides all the connections you need.
    Liversedge, Westyorkshire
    we have cdr2005 in our vectra, if you get it fitted please tell us how!!
    North east HQ
    as juzzy said, you dont even need to touch the radio quadlock. if you take the glovebox out, if the plug is there then it will be taped up to the radio wiring harness. all you'll need is a suitable adator which are about £15
    Sutton Coldfield
    Default Astra forums
    Hi All
    chunkster, you're right, looks as if i've not got the right connectors on the car kit. had a look around the glove box, and the back of the radio but can't see anything suitible.
    checked on a few astra forums and the mk5 (05 plate) have different connectors to vectra c's.
    JuzzyD - what does the VDA plug look like? the two connectors on my ck7w, do i just attach the one of them?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    'fraid you're looking in the wrong place, mate. This piccy shows (not very clearly) the plug for the phone kit (outlined in red.) The black box is the ck7-w box.
    Phil
    Jun 2006
    Somewhere...
    Yep, its the one SignumPhil has highlighted in the picture (its got a little swing arm on it).
    Easiest way is to get a Vauxhall to Nokia Autoleads cable - straight plug and play then.
    it is if you get the right one, had 2 so far, the company that got them for me has now gone bust, with my lead in the place. motorworld. t**ts.
    Sutton Coldfield
    Mrs wez, any joy with a lead?
    i had another look at this setup today and can't see how my lead fits - suprised i need to get another lead when i've got a vauxhall loom on the nokia kit.
    if i don't touch the blue connectors ni the back of the cage, i can't see any connectors i can put it to. Has anyone got a photo of the correct connector?
  1. nokia ck7w bluetooth car kit
    By stuart bigboy in forum General items for sale
    Last Post: 21st January 2010, 09:19
  2. nokia ck7w bletooth car kit
    By stuart bigboy in forum Parts for sale
    Last Post: 17th December 2009, 18:32
  3. Nokia CK7W install
    By goosey_1976 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 18:09
