Thread: vectra c 2.2 direct auto HELP PLEASE
    Regular Member davidlewis24's Avatar
    bridgend / wales
    Default vectra c 2.2 direct auto HELP PLEASE
    hi all im looking for some help if possible please. when driving the car ive noticed the last few days that when breaking the noise is very bad ive been getting a drowning noise ??? anyone else have or had this problem as its getting on my nerves
    thanks
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    you need to have a look at your brake pads as they could be worn down,a corroded disc can also cause a noise,you need to look on both sides as sometimes the inner is corroded where the visible side is ok
    Mileage : 000
    without hearing the noise. It might be the pads are worn down to the metal backing plate and are now rubbing on the disc,s. Is it a metalic sort of sound?? If it is the brakes you will need to get them sorted imeadiatly...
    bridgend / wales
    the car breaks as it should but the noise is like a whirling drowning sound which you can only hear inside the car
    Mileage : 000
    I s there any "play" in the wheels when you wobble them. Could be the rear wheel bearings.
  1. Vectra 2.2 Direct Auto Car and Spanner light
    By m2yuout in forum Engine & Drivetrain
    Last Post: 11th February 2013, 20:43
  2. Replies: 9
    Last Post: 25th August 2012, 18:14
  3. 2.2 Direct Vectra Auto Gearbox - Strange Problem
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 7th May 2012, 21:12
  4. 2.2 direct auto oil
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2010, 13:32
  5. vectra c 2.2 direct auto gearbox oil help
    By davidlewis24 in forum Engine & Drivetrain
    Last Post: 5th May 2010, 17:04
