Results 1 to 10 of 18
Thread: Map light help
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Default Map light help
    Just bought the map reading light upgrade from lmf. Has anyone one here done this mod or taken there existing one off? Is there anything I need to know about this to fit it, and is it just plug and play? Also the pic has 4 switches but my mate has the gsi with light fitted and it only has the 3, so what is the fourth one for?
    Regular Member peterm's Avatar
    Jan 2006
    Liverpool
    I looked at getting one of these and asked LMF what the fourth button was for. They said it was to turn all the lights on / off.
    Dec 2005
    RUNCORN
    hi peterm your right it is were are you from in the pool
    North east HQ
    i think its to turn off the rear interior light if its fitted
    Jan 2006
    Liverpool
    Yes it turns on / off all the lights including the rear one if fitted.
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    If you've got kids that won't go to sleep on long (nighttime) journeys, you can switch their (rear reading) lights off!
    Doug
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Thought it might be for that cheers. Got the back light to fit too, am really not looking forward to doing that nasty little job.
    Really easy to do mate, just a couple of torx screws to take out, the whole thing then unclips, front first then pull it down, ( the glass just pulls out, as does the blank plate where the sunglasses holder goes) unplug and plug the new one in and push into hole, replace torxs and Roberts your Mums brother ... Make sure you push the plug right home as I didn`t and got a safeguard error and had to take it apart again, not so easy with the sunglasses holder in place ...
    The four buttons, end ones are for each map light, middle two are 1 for on/off the other is an off so the light doesn`t come on with the doors ....
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Nice one, just what I was after, cheers bainie.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Just did this upgrade (after sifting through this ace forum and getting some tips!).
    Just to help anyone else that does it, I plugged everything in and had "Safeguard" appear on the computer. After a lot of connection testing I finally tried setting and unsetting the alarm.
    Seemed to reset the system, all working great now.
    Rear interior light will be next mod.
    Cheers P
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
