Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: 2.2 direct - trouble starting/running
    Regular Member Ant SRi's Avatar
    Merseyside
    Default 2.2 direct - trouble starting/running
    Hi,
    I have 2.2 direct (04)
    Over past few months, car occationally would not idle correctly and stall, but a restart would always cure it and be fine.
    However today it will not run correctly. When starting the rev's are only about 500rpm, if the throttle is pressed the car stalls. If the throttle is pressed VERY slowly the revs can be built up, but when ever go to drive off the revs drop and stalls.
    I've checked the air filter, air flow sensor, spark plugs - all those seem to be okay. I've seen on other threads that the fuel pressure reg is a common fault - do these symptoms sound typical of a FPR failure?
    Is there a way I can test the FPR or anything that I can do to service it?
    (car has just passed 100k)
    Cheers,
    Regular Member daneboy35's Avatar
    darvel,ayrshire
    Possible throttle body choked
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Also the exact symptoms of a duff EGR on the YH. Have you had the codes read?
    Merseyside
    Not had codes read - but there is no engine light on....
    more likely to be EGR than fuel pump/reg then?
    Where is it located and is there anything I can do to fix it, clean etc?
    Vehicle : SRi
    Mileage : 137000
    It could be anything mate, lets just hope its not the FPR or Pump.
    The EGR on the YH is water cooled so will require the system to be drained if you take it off. VX can disable the EGR in the SE and YH so if its that it would be fa cheaper than a pump. First off I would get the TB off and get it cleaned like Colin mentioned, if that does the trick then all sorted for the price of a can of carb cleaner. If its still playing up then getting the codes read is the next step. I believe the code is P1405(62) for a dicky EGR. HTH
    Merseyside
    ok thanks mate will do .
    Merseyside
    Where about is the EGR on the YH engine?
    Vehicle : SRi
    Mileage : 137000
    This is my EGR, different to yours but in the same place. (the silver barrel) Its on the battery side of the lump.
    Merseyside
    Thanks mate. I presume if the valve is stuck open, then getting it disabled wont help...?
    Merseyside
    I've also just noticed that the long black plastic bar just below the intake (I presume this is the trottle linkage) the silver thin metal rod that fits through the right hand side of the bar was out of the location hole and so when the bar moved the rod wasn't - if that makes sense!
    I thought I'd found the prob, but put the rod back through the bar and was just the same. This bar is over to the right when the engine is off, when I try to start it is hard over to the left - is this right?
  1. Trouble starting
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2009, 17:48
  2. trouble starting?
    Last Post: 20th October 2009, 17:22
  3. Trouble starting
    By Daywalker in forum Engine & Drivetrain
    Last Post: 9th February 2009, 17:55
  4. Trouble starting.
    By Gr4eme in forum Troubleshooting
    Last Post: 24th February 2008, 22:27
  5. Trouble Starting
    By JCB in forum Engine & Drivetrain
    Last Post: 7th February 2007, 12:34
z22se actuator rods
