Results 1 to 10 of 18
Thread: Losing Coolant
    Jul 2006
    Eek Losing Coolant
    My coolant warning light came on a little while back, so I checked it and found it was a bit low. About an inch below the 'MIN' marker in fact
    Anyway, I topped it up with water, but noticed that there was a gunky, oozy, nasty, slimy mess that looked like it had leaked from one of the pipes and dripped down the outside of the coolant expansion tank. I cleaned it up and hoped for the best.
    Bad move.
    I noticed a smell while sitting in traffic yesterday, a kind of chemically burning smell. Checked the temp gauge on the dash, but no problem there, sitting at 90 degrees, same as always. The traffic started moving and the smell disappeared. I got home, popped the bonnet and there was more coolant residue down the side of the expansion tank.
    I'm obviously going to get it booked in to have it sorted, but how much water is it safe to add to the coolant before it loses its antifreeze properties? I've already added about a pint from the other week - do I need to top it up with coolant this time or will water be OK again?
    TIA
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    keep some mixed up just, and just add it to whats in the header tank
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yep should put pre mixed coolant in esp now its getting really cold at nights
    Jul 2006
    Do I need Vx coolant, or will the Halfrauds own brand stuff mix OK?
    as long as its the red stuff
    Jul 2006
    The stuff that's leaking is a yellow/green colour though....
    Quote Originally Posted by parapaul View Post
    i though vx only used red/pink colour anti-freeze
    Jul 2006
    Regular Member poves's Avatar
    lancashire
    I had this on my 3.2 , the oil cooler had failed and the cooling system was pressurising , forcing coolant from the header tank ( same symptoms as head gasket failure.)
    The oil had spewed into the coolant which discoloured it and then clogged the coolant lines.
    Not a nice job to sort mate , don't know what model u got but it's worth looking into the oil cap to see if theres any scum there as well.
    Jul 2006
    Thanks for that, I'll have a look. The oil was as clear as honey in July so it should be obvious...
    Its a 2.8T BTW
    Thank god for warranty, eh?
  1. losing coolant 150 cdti
    By elite_150 in forum Engine & Drivetrain
    Last Post: 25th February 2013, 22:36
  2. Vectra 3.2 Losing Coolant :(
    By HelloVauxhall in forum Engine & Drivetrain
    Last Post: 7th November 2012, 20:09
  3. Losing coolant but where??
    By Legion84 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 12:27
  4. losing coolant
    By TonyTangles in forum Vectra C / Signum Troubleshooting
    Last Post: 27th December 2011, 22:30
  5. Losing coolant
    By connery-sri in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:44
