Results 1 to 10 of 17
Thread: Dismantling front suspension
    Regular Member danlat1415's Avatar
    Lancashire
    Default Dismantling front suspension
    Hi guys.
    I've been trying to change my suspension all day.
    I've managed to get the full front strut/spring off, but Now I can't dismantle it...
    I need the top piece, and the rubber trim to put on my new strut and spring.
    At the very top of the strut there is a Nut with a torx bit in the middle. I have tried unscrewing the torx and the nut, but the top of the strut just spins round with it, and doesn't unscrew..
    Here is the NUT with the TORX bit in the middle.
    I have tried putting the top piece in a vice and trying to unscrew it that way.
    But the top metal rod of the strut (shown exposed in this picture) keeps turning when I turn the nut, so it doesn't unscrew.
    Can anyone tell me how to get it of??
    Dan
    Regular Member Baz07's Avatar
    Lancashire
    Dan when Drinky did mine he had a ring spanner on the top nut and then used a torx bit to hold the centre piece still whilst undoing the nut.
    HTH
    Tyneside
    When I done mine it was just a case of an angled spanner on the nut and a torx bit in the bolt then turn the opposite way to unscrew.
    Mileage : 000
    You will have fun here if you don,t have the correct ring spanner. I use a 7/16 or 1/2 whit ( I forget which size fits the nut) whit ring spanner it has a deep "ring" on it so it sits down on the locknut, then with a torx socket I undo the nut. Make sure the spring is clamped firmly as the lot will go up in the air when you remove the nut.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    Quote Originally Posted by Baz07 View Post
    HTH
    Lancashire
    Thanks for the advise guys.
    Does anyone know what ring spanner I need then?
    I'm going to have to hunt round and get one tommorrow because the car is parked on the drive with 3 wheels on
    Also, which do I turn clockwise? the nut or the torx?
    I'm taking pictures of the process so I can upload the How2 when I finally get finished. That way others have a step by step guide...
    Lancashire
    You hold the centre shaft static with the torx bit then turn the nut anticlockwise
    Tyneside
    Turn the spanner anti-clockwise and the torx bit clockwise IIRC, you'll know when you start turning it or just look at the thread of the bolt to see which way.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    put the strut back on the car. then loosen the nut just to take the tension off. remove strut put on clamps and then remove nut.
    see here.......http://forum.vectra-c.com/showthread.php?t=42841
    Regular Member old cruiser's Avatar
    slough
    that's what I've always done and I've removed quite a few over the years and makes the job much easier.
    Cheers Pete
  1. Dismantling gear lever assembly
    By Gazza36 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2011, 23:29
  2. front suspension????
    By Tayla in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 17:28
  3. Dismantling the face plae from a CD70
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2009, 20:00
  4. Front Suspension...
    By dankidd in forum Suspension, Wheels & Brakes
    Last Post: 30th October 2008, 01:04
  5. Drivers door switch unit (windows, mirrors etc) dismantling Q.
    By MadOnVaux! in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2006, 20:09
