Results 1 to 10 of 14
Thread: tc switch and mystery plug
    Regular Member keeton's Avatar
    notz
    Default tc switch and mystery plug
    iv read about taking the blacking plate out of the dash pannal and fitting the tc button im going to try that but i poped the left hand side blaking plate out and it also has a plug can any one tell me wot its is also i tinted my rear lights at the week end and found a plug in te rear can anyone tell me wot it is
    plug in the boot righthand side behind pannle
    Tyneside
    I'm pretty sure the left plug is for the parking sensors and I'm betting on the plug at the rear is also for the parking sensors.
    Regular Member Baz07's Avatar
    Lancashire
    Lower left is the Park Pilot switch
    The plug i was informed is for the Tyre pressure management system
    Full Member Big Sig's Avatar
    I think the bottom left one is for the front parking sensor switch. Also, Im guessing that "wot" means "what" so i hope i've understood your question correctly
    The rear one MAYBE for the rear tpms or something similar
    Mileage : 000
    Yep, it is for the parking sensor switch.
    Regular Member Ian G's Avatar
    Merseyside
    Dash switch is S258 Park Pilot.
    Boot connector is A157 Tyre Pressure Monitoring System control box.
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Cut it off and send it to me
    Mileage : 000
    Got a new idea you want to try Dean
    notz
    thanks lads i dont have parking sensors so ill cover it back up can i do anything with the plug in the rear then and wot do i need thanks
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    You'd need the TPMS receiver and 4 valves sensors (dont get from Vx though as they charge too much) plus 2 senders to be fitted on the near side of the car underneath the wheel arch liners and then get it tech2'd on... But you may not have the right looms for the front and rear axles unless you have AFL lights or such
  1. mystery plug nut Z18xe
    By wilson002 in forum Engine & Drivetrain
    Last Post: 11th February 2013, 17:31
  2. Found A Mystery Grey Plug
    By AdeV6 in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2012, 22:05
  3. whats the mystery plug for
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2012, 18:37
  4. mystery plug under the glove box...
    By korlinski in forum General Chat
    Last Post: 15th June 2007, 08:59
