Thread: Temp Gauge An Heater Probs Any Ideas
    west yorkshire
    Default Temp Gauge An Heater Probs Any Ideas
    Hi going down motoway last week an temperature gauge dropped to zero, ever since it dont seem to work and the heater only seems to blow luke warm, have checked water level thats fine, is there a fuse , and do vectra c s have a thermastat like older cars , any help appreciated thanks, .
    11 Post(s)
    Yes, sounds like your thermostat is stuck open.
    Regular Member s0501291's Avatar
    Warrington
    I put my Vectra C 2003 in for a full service last week. When I got it back the temperature gauge wasnt working. They had replaced the "oil switch" on the sump as it was leaking so thought maybe somthing to do with that. Rang the garage up and they said bring it back in, they looked at it and said it was nothing that they had done. The gauge has since struggled up to the 1st mark OR it works normally, then not at all. The length of the journey doesnt apear to effect it. I did 80miles on the motorway the other day and NOTHING, then did a quick run to the shops and it worked fine!!, any ideas?
    Pete
    west yorkshire
    Sounds same as mine , gona try looking at thermostat will let you know the outcome , thanks for your reply,
  1. temp gauge probs please help
    By alshel in forum Engine & Drivetrain
    Last Post: 30th October 2013, 13:55
  2. engine coolant/temp gauge/heater
    By redmoog in forum Engine & Drivetrain
    Last Post: 1st December 2010, 21:37
  3. engine coolant/temp gauge/heater
    By redmoog in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:27
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Temperature gauge probs..
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 7th February 2008, 08:18
