Thread: vectra 2.2 ticking over too high
    Regular Member keeton's Avatar
    notz
    confused vectra 2.2 ticking over too high
    hay every one my car has just started ticking over very high its ok when you first start the car as soon as you drive it away it will tick over at 1500 until i turn the car off any one have any sugestions thanks
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Is it at a constant 1500?
    or does it keep dropping like its going to stall then rev back up to 1500?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sound like your letting air in somewhere. The fueling is adjusted to match air flow, so the less air the lower the revs. First give the TB a good clean, open the butterfly and clean round the back, a dirty TB is the most common cause of erratic/high revs.
    notz
    its a constant 1500 ill give that a try thanks for your help
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Its best to just unbolt the TB mate. If that fails check for air leeks inbetween TB and head, so all vac hoses and seals from TB to manifold and manifold and head.
  1. vectra c 1.9cdti xp2 very loud and ticking engine noise
    By atty in forum Engine & Drivetrain
    Last Post: 26th August 2012, 14:07
  2. Vectra ticking sound no longer present
    By kevin75 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 22:46
  3. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  4. 05 Vectra CDTi - ticking when cold
    By gmc in forum Engine & Drivetrain
    Last Post: 26th September 2010, 08:25
  5. Vectra C 1.8 SRI engine ticking noise
    By peternotails in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:25
my vauxhall vectra has started ticking over high
