Results 1 to 10 of 11
Thread: 2.0 DTI Starting problems.
    Glasgow
    Default 2.0 DTI Starting problems.
    Hello all.
    I'm new to the forum, new to diesels and new to vectras.
    I have a 53 plate 2.0DTI LS and it's stuggling to start in the cold mornings. It has also happened once in the not so cold mornings.
    I turn the key, let the glow plug pre-heat light go out and turn the key to start it, it fires briefly and then cuts out.
    After this, it takes ages to fire again, and when it does it produces clouds of white smoke, then it's fine.
    Any help is greatly appreciated!
    David
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    enjoy mate im sure there are lots of people who can help you iv never had a DTI so not much use sorry
    Just wondering do DTIs have throttle bodies could it be clogged i had a problem with my 2.2 Direct and that kept cutting out after just starting cleaned it with carb cleaner not a problem now
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No throttle bodies on diesels, as no throttling of intake air.
    Do a search for leak off pipes on here, classic symptoms and luckily doesn't cost a lot either.
    I bet it starts OK for the rest of that day too? I also dare bet that it is more apparent when parking nose up on a hill?
    Essentially, there are small rubber pipes connecting the fuel injectors together and then returning by-passed fuel back to the fuel system. These deteriorate over time and heat and start to allow air in. the fuel then drains back to the tank and you have to crank and crank to get the thing to starts. The initial start (for approx 1-2 seconds???) is just the remaining fuel in the lines / pump.
    Glasgow
    Thanks Ste, you're bang on mate.
    As for nose up, i suppose it is a little bit, i'll try reversing it onto the drive and see if that makes a difference.
    As for these pipes, where are they and where do i get replacements? Do you guys have a service manual i can download with diagrams?
    Thanks for the help so far, sounds like a common issue.
    Regular Member dutch's Avatar
    port glasgow
    cheers for bringin that thread davie was about to do the same thing all of the things ste said are exactly the problems i have also and the cars nose is parked uphill and thanks to you ste
    Regular Member raymie.d's Avatar
    Feb 2007
    Glasgow
    Alright Davie my man, good to see you on the forum. Vauxhall would be the best for parts, Arnold Shark down on Hamilton Road, the parts guys in there are tremendous I have never paid full price always on for a discount or two, just mention that you have been on here looking for the answers should be good for 10% off parts.
    Feb 2007
    Glasgow
    Loving your avatar dutch. Superb. We are the people!
    Glasgow
    Aye, how long i'm a member is the question, i blame you for it all, personally.
    Feb 2007
    Glasgow
    I only found out you had bought one after you got it. And how am I to blame??
    Glasgow
    Cos. You just are.
  1. 2.0 DTi - Starting problems.
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 01:22
  2. starting problems
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 17th September 2012, 10:03
  3. Starting problems
    By Venom1924 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 23:55
  4. 2.0 dti starting problems
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 11th October 2011, 18:47
  5. problems starting
    By jasoncow in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 23:24
