Thread: That "Doh!" moment
    Regular Member SignumPhil's Avatar
    Luton, Beds
    Default That "Doh!" moment
    Driving home in the Astra last night, I was muttering to myself about how slow diesels are to warm up. Then I spotted the yellow LED on the dash, turned off the air con, and things suddenly warmed up. DOH!
    .........And, yes I know, the AC doesn't work below 4 degrees C. It was a toasty 6 degrees driving home last night.
    Phil
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    haha silly
    Apr 2008
    Liverpool
    does your aircon come on when you start your engine or did you put it on by mistake???
    Luton, Beds
    Quote Originally Posted by Sean-2.2Direct View Post
    No idea. If it's off, it should stay off.
    I blame my big clumsy banana fingers. Or maybe the dog. Most things get blamed on her in our house.
    Phil
    Apr 2008
    Liverpool
    haha you probably just knocked it on by accident last thing you want is air con on in this weather.
    haha is the dog always in the wrong place at the wrong time
    Regular Member MLC's Avatar
    uk
    Air con doesn't just cool. It also removes moisture from inside the car and prevents misting up. And if you turn it off all winter, the seals will dry out and you'll knacker it.
    Regular Member shan's Avatar
    I had the same on the wife's astra. I thought it was coming on when you started the engine up. But i thought i could not be It's one of those things you say to yourself i must keep an eye on that when i get in but never do.
    Luton, Beds
    Quote Originally Posted by MLC View Post
    Oh, I know that -I'm just used to the Siggy, which has climate control and sorts itself out.
    The demisting trick was a great revelation when I had my first air conditioned car. (a '97 Mondeo).
    I always try to give the AC a run every now and then through the winter. Don't want to knacker it! It's been so *&^*^!! cold these last fews days, every little helps.
    Phil
    Regular Member Small Racer's Avatar
    Jan 2008
    Hampshire
    I have always just left my AC (Climate Control) set to both sides the same temp - AUTO, AUTO RECIRC, and just change the temp with my side, either up or down. To clear the screen in the morning just press the right hand side button (with the windscreen on it) - and it clears - then press the AUTO button and just leave it set at 21 or 22 if wife in car.
    Is this wrong - should I turn it to ECO for the winter?
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Well you can tell the cold weather is with us again cos my heaters are total and utter $h1t and my temp gauge doesn't move.
    Gets lovely and toasty if i leave it ticking over for about 45 mins but that's just not good practice or cheap.
    Can't wait to use the other half's old L reg Pug 306. You can bake potatoes in the footwell in that thing!
    Snowman, you got your ears on?
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. "MAN" it's great to be alive moment
    By Derek Mc in forum General Chat
    Last Post: 12th November 2011, 10:57
  3. Replies: 55
    Last Post: 9th February 2011, 13:05
  4. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  5. "Goodbye" grey sky, "hello" blue !
    By FIL 4822 in forum General Chat
    Last Post: 24th October 2008, 12:34
