Thread: Check Your Drain Holes
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default Check Your Drain Holes
    I got a call from my Father asking for my help as all the front and rear n/s interior was soaking wet, in fact there were puddles in the car.
    My first thought was the drain holes around the pollen filter as the water had come out of the floor vents, and sure enough when I lifted the panel water was half way covering the pollen filter.
    My Fathers car is an Omega so I wasn't sure where the drain holes were but I found a bung on the inner wing which I prized off and out came a waterfall. I then dried up the rest with cloths and eventually found the drain point at the bottom which was coverd in about 2" of crap. I got everything working again and replaced the Pollen Filter and then striped the interior and vaxed the carpetsand underfelt until dry which took allday.
    I know this has dragged on but in Febuary the car was serviced by Arnold Clark and obviously they did not check or replace the filter.
    BEWARE
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I don't think checking of the drain is a service item ever.
    Even if they had changed the cabin filter, do you think they would check the drain anyway - doubtful.
    I checked mine the other week and everything was clear
    May 2007
    Doing stuff
    It happenend on my Omega, below the pollen filter there is a rubber bung with a cross cut in it to drain. it gets full of leave debris etc fills with water a floods the passenger footwell.
    A stiff stick and skinned knuckles cures it.
    Mine got taken to the dealer to sort the problem. But because it did not show up on tech 2 they didn't have a clue.
    "Bless each and every one of them."
    Surrey
    I park near a tree and I am always having to clear leaves out at this time of year.
    Uxbridge
    Can someone tell me where to look exactly for the filter, bung etc as I've got the exact problem in my SRi..
    Also does the interior need to come out to dry it out properly?
    Regular Member shan's Avatar
    Quote Originally Posted by johnhol View Post
    If you lift the bonnet and on the righthand side just below the windscreen you see a little split in the black pastic trim. "about 2inch split on the right and 1 inch split about 14 inch's to the left of it"
    Pull the flap up away from the rubber seal. And inside you see the filter, at the very bottom of the filter you should see the bung hole.
    Just make sure any crud is removed.
    Not sure if your carpets are wet but it's a lot of work getting them out. I'd just vax it all out and let dry.
    Regular Member Lump's Avatar
    coventry
    ok will take a look at this, i smoke, and left some Rizla in the car went to use them and they were all stuck together, and windows have been misting up the last few days
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The drain point exits into the engine compartment on the bulk head and has a black rubber tapered end directed downwards
  1. pot holes!!!!!! who needs them :-(
    By Petiemc in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 08:46
  2. F********** pot holes!!!
    By paddyvectra in forum South Central (ARO - matty2fatty)
    Last Post: 1st February 2013, 22:28
  3. What to do with my holes....
    By danBoy in forum Styling
    Last Post: 24th April 2010, 16:04
  4. Pot Holes
    By ed taylor in forum General Chat
    Last Post: 4th February 2010, 17:02
  5. Pot holes!!!
    By Cruize in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 21:42
vauxhall vectra drain holes
does a vectra c have an inner wing drain
vectra c drain holes locationvauxhall vectra drain holes site:www.vectra-c.comvectra c drain holesopel vectra c drain hole
