Results 1 to 10 of 25
Thread: Steering warning light - help
    Regular Member danlat1415's Avatar
    Lancashire
    Default Steering warning light - help
    Hi guys,
    Over the past month, I've been getting the steering warning light come on a few times a day. I don't know if it's because I'm aware of a possible problem, but the steering does feel quite light, and a take it very carefully when turning corners, because it feels like I'm going to turn the steering wheel and the car will carry on forward.
    I don't know if my suspension is affecting the steering because that's knackered, and i've changed the back, but the front is due the weekend (struggling to do it after work in the dark)
    The warning light comes on the dash 8 out of 10 times that i go round a roundabout (i don't drive silly, normal 20mph or so round a smallish roundabout. The light also comes on if I go round a normal corner and there are bumps in the road. Like with the rear suspension when it feels like the rear end will swing out, this feels like the front end will swing out.
    I'm changing the front suspension this weekend, so hopefully that will cure it, but does anyone have any thoughts to what might be causing it, and i PRAY it's not expensive.
    Dan
    Full Member Big Sig's Avatar
    Could be the sensors on the steering rack, but thats just a guess.
    Lancashire
    I'm worried that it's not just a sensor issue, but something is not right, because the steering feels light and not responsive enough.
    Could it be the power steering fluid low? How would I check this?
    Also could be the pump..?
    just my thoughts.
    The power fluid is located near the bumper somewhere I believe, don't think its too easy to get too. have you thought about getting the faut codes read?
    Regular Member oldmanmille's Avatar
    Cheshire
    Thumbs up
    I have got the same problem but my light is now on all the time and so is the traction control. I have already asked the question today on the forum but it appears nobody else has had the problem or just not saying!
    I have had the codes read and it points to the snsor/s which I am told will cost £600 or so. If it is that then fine but I would rather know 100%.
    If someone can help two of us now it would be appreciated
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    my light used to come on sometimes and if i stopped and restarted it went out . i topped up the fluid and it was fine it never came back on ..pelll back drivers iner wheel arch cover to revel .or take the bumper off its easyier and less messy
    Dec 2005
    AYRSHIRE SCOTLAND
    you can just se the bottle here
    Cheshire
    cheers Rory I will have a go this weekend. Appreciate your comments....here's hoping! John
    Lancashire
    Yeh cheers for the pics and advise!
    What do you top it up with? and is there a mark with max and min levels?
    I'll have a look at mine this weekend too. Hopefully that'll be the cause and solution. Got to finish from suspension anyway, so I'll just make a day of it.
    Regular Member garvey's Avatar
    Co Durham
    My sensor went on mine £5 from local breakers.
  1. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  2. power steering warning light!
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 20:36
  3. Steering wheel warning light?
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2009, 22:33
  4. Power steering warning light !!!!!!!!
    By Scott_C in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2007, 19:00
  5. Steering wheel warning light
    By mooj in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2007, 10:00
