Thread: GSi de-cat
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default GSi de-cat
    Following on from GSi3.2's cat removal http://forum.vectra-c.com/showthread.php?t=59699, I've enquired with MIJ at Walsall to do the same and just got a reply back:
    "The de-catpipe in stainless steel you've requested for your Vauxhall Vectra-C will cost £44.99 this is fully inclusive of fuel discount (£25), vat & fitting. "
    Might just take a trip to Walsall
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    do you need the cat for an mot?
    No you don't need a cat for an mot, just the emmissions need to be below a set point. GSI3.2 didn't remove all the cats anyway, just the last one in the main exhaust, not the precats
    Regular Member lilangel's Avatar
    bucks
    actually, turns out an mot centre can refuse to test you if you dont have the cat, even though your emmisions are right......
    Jul 2006
    I think you're right - but they have to know that it's missing first
    Regular Member Karl's Avatar
    Sunderland
    Plus you aint removing all the cats so you still have one. The cheap way around decatting is to remove the cat, bas the innards out with a screw driver and hammer, clean it out, and refit, then it looks like you still have one, and its free! (well, maybe an hours work)
    Quote Originally Posted by lilangel View Post
    How could they?????? The 3.2V6 has 3!! your only removing one. Where does it state you have to have a cat fitted
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    There's a forum, would you believe, for MOT testers . A couple of threads on there from MOT testers that say you don't have to have the cat in place, it's the emmissions that count (as Mark said).
    Quote Originally Posted by gtr1000 View Post
    Yep, I have just been looking at those too! As long as it meets emmissions requirements for that year of car then there is no problem
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Immoral IMO to remove emissions reducing devices, and it will do something or it wouldn't be there at all.
    Rodding out the cat might actually decrease power, as it may increase back pressure due to the fluid dynamics of the exhaust gas flowing through an empty canister, with shape changes that were not are modelled / tested originally.
    Also be aware that Section 59 of the Construction and use act MAY be violated.
    You cannot modify the exhaust system of the car such that it produces more noise than when originally registered.
    Not many police forces carry the kit required to perform tests at the roadside though, so the likelihood of being 'done' are small.
