Thread: Brake rewind tool URGENT!!
    Regular Member Tony12's Avatar
    Peterborough
    Engine : 1.9 CDTI
    Mileage : 142000
    Default Brake rewind tool URGENT!!
    Hi people hope you can help me, think i'm being a bit stupid!!
    I am doing the rear brakes on my vectra, have bought the rewind tool off of ebay
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...B:EOIBSA:UK:11
    But i'm not sure how to use it, keep trying the bits in different places but it keeps falling out or doesnt seem to be pushing in when it is turning.
    Any help would be appreciated as need to get them done before tomorrow afternoon!!
    Sunny Dartmoor
    It should just fit on the caliper and act as a wind in piston itself,you can't really get it wrong m8.......
    Might need some pic's to explain....
    Mileage : 000
    Obviously you have removed the pads. Then I would say you need to locate the appropriate "C" spacer into the C shaped slot on the caliper, Locating the large lip on the collar into the "c" spacer. the two pins in the end of the re-wind/threaded shaft locate in the piston, by holding all the parts together with one hand wind the tool so all the slack is removed from the thread. Then gently wind the piston back into the caliper housing. That is how I would say you use it by looking at the ebay picture.
    If you still are not sure how to do it. I would suggest asking a friend or mechanic who has used a tool like this before.
    Peterborough
    Engine : 1.9 CDTI
    Mileage : 142000
    Hi thanks for the replies. The first caliper i did the piston was to far out to get the spacer in so had to wind it in with a bit of force first. 2nd was easy!! Don't feel so stupid now!!
    Mileage : 000
    Glad you got it all sorted.
    Sunny Dartmoor
    South Wales
    Default rear brakes replacing
    Quote Originally Posted by Tony12 View Post
    Hi Tony Did My rear brakes today, I clamped off the flex brake hose then disconected it so I could wind the piston in without resistance, then wound in the cylinder with a set of nosepin pliers I gave it a soft tap with a hammer from time to time, But it does take a long time to wind it in. the cylinder winds in clockwise, and anti clockwise to wind it out. hope this helps I did not have the correct tool for the job but as long as you can wind it who cares, hope this helps
  1. Help Brake rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2013, 22:34
  2. brake rewind tool
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2009, 16:24
  3. Brake Rewind Tool..
    By snapsnap in forum Suspension, Wheels & Brakes
    Last Post: 4th November 2009, 22:31
  4. brake rewind tool
    By taxidriver50005 in forum Suspension, Wheels & Brakes
    Last Post: 28th April 2009, 19:38
  5. BrAkE REWIND TooL ????
    By StarDingle in forum Suspension, Wheels & Brakes
    Last Post: 28th October 2008, 15:18
