Thread: Rear washer jet
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Default Rear washer jet
    Anyone able to tell me how to go about re-fitting the water pipe to the rear window washer? It popped off on the M6 on the way back from boxing this morning.
    Can you do it by removing the ariel assembly? If so how do you do that?
    Regular Member Harry's Avatar
    Uxbridge, London
    afraid i can't help you here Mikey.
    how did you notice it had come off anyhow? nice little waterfall effect on the inside of the rear windscreen whenever you activated the jet??
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Think its the same set up as the vecb which means you can prise the jet from the ariel base,but the tube runs across the headlining and into the ariel base which means you have to drop the rear lining to get to the base bolt which holds the unit to the roof...
    Dec 2005
    Quote Originally Posted by hmha0
    Squirt, pop, trickle-trickle...
    Dec 2005
    Quote Originally Posted by IamtheStig
    Darn it, that's what I was afraid of.
    Next question then, how does the headlining come off? Is it east to do?
    Uxbridge, London
    apparently so, alot of people have taken them down at some point or other in order to do the rear interior light modification. i think it just unclips from the back.
    Dec 2005
    Cheers guys, i'll have a look when the sun comes up again.
    Inverurie
    Undo the rear grab handles, and gentle prise the lining from the ceiling. Watch out as there are three VERY sticky/grabby velco patches which are a pain in the bum
    Andy
    Nov 2005
    Somewhere in time
    If you've got a crappy radio signal then now's the time to change the whole thing,i had it done under Network Q
  1. Rear Washer jet
    By Vectra-c-SRI in forum Bodywork & Interior
    Last Post: 30th January 2013, 01:04
  2. Rear washer jet.
    By burbling1 in forum Bodywork & Interior
    Last Post: 8th November 2012, 22:22
  3. Where's the rear washer?
    By stoneyloon in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 20:56
  4. rear washer jet
    By bret.c in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 15:04
  5. Rear Washer.
    By ashdog in forum Bodywork & Interior
    Last Post: 27th August 2006, 07:43
