Thread: Handbrake bypass
    Regular Member Dippy-Vx-line Red's Avatar
    Earlston (Scottish Borders)
    Default Handbrake bypass
    Hi.Just installed a new dvd headunit wired in and working.o\nly trouble is when trying to play a dvd i get the message stop car blah blah get sound but no picture..I grounded the brake wire to the black ground wire on the iso block so thought that would have bypassed the handbrake control.Any advice would be welcome....
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Is it registering a speed input from the road wheels?
    The normal HU takes a speed input to adjust the volume as the vehicle speed increases - just a thought, as how would it know you are moving?
    Is it OK when the car is stationary?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    As you are aware having the DVD playing while you are driving along is illegal so why would you want to do it?
    If you where to have an accident and they found that you had altered the player then you would be in big trouble. Leave it as it is and drive safely, please
    Regular Member lochgilp's Avatar
    argyll
    what make of headunit is it mate? as grounding the brake cable usually does bypass the handbrake!
    Blantyre
    I had the same issue, but i didnt wire it up to the negative to make it work, honestly i also hear you can tape it onto the chasis cage with some insulating tape,
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by merikiito View Post
    Only if the driver can see the screen???
  1. egr bypass thought
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2012, 12:17
  2. CanBus bypass
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 08:58
  3. 150cdti EGR bypass.
    By mally in forum Diesel Engine related
    Last Post: 14th April 2011, 00:18
  4. bypass ABS sensors
    By IA76 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2009, 16:53
