Thread: Footwell Leak HELP!!!!
    Regular Member Tigger_NI's Avatar
    Jun 2006
    Northern Ireland
    Default Footwell Leak HELP!!!!
    hi all, i have a leak in my passenger side footwell and cant id the cause so any help or ideas u have would be great...
    I have changed the p-filter and cleared the waste pipe under it, door n window seals are gd also. im at a real loss ive dryed the carpets 3 times thus far.
    The area effected is that directly around the mat fixing stud nearest the door, under the glove and other areas remain dry.
    Ne help at all would be great, thanks
    Craigy. T
    Surrey
    Are the roof rails clear?
    Jul 2006
    Mexico
    I think the aircon might be the guilty...AFAIK there is a tube tho take out condensation...if it is obstructed it might leak inside
    Jun 2006
    Northern Ireland
    Yep roofs clean n clear!
    Ok the A/C tube sounds like a fe*ker to check, is it sumthing i can do or am i looken for a wrench-monkey
    Surrey
    but have you used the AC recently? Open hose with you inside maybe an option. I hate leaks...my girlfriend has a convertible.
    Jun 2006
    Northern Ireland
    EEEEPPPPPP!!!!!!! im afraid i have used the AC, ive used it few times to clear the front screen, like it says in the handbook.
    I had that problem, turned out to be the windscreen seal
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Check out this thread:
    Sounds like it could be the bunged up drainhole by the pollen filter.
    Especially with the onset of Autumn
    Jun 2006
    Northern Ireland
    So much for a cheap n easy fix lol....... there ne way to check n see for sure that its the wind screen seal, as it looks ok ??
    ive checked n cleared the drain holes few times, but once more wont hurt
    cheers for all the help
  1. Oil leak 150 cdti oil leak help
    By sr_fly in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:46
  2. wet footwell
    By kewley in forum Vectra C / Signum Troubleshooting
    Last Post: 28th June 2011, 21:05
  3. Vectra c passenger footwell leak
    By bigjoe8707 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2010, 08:02
  4. wet passenger footwell
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 20:40
  5. Leak, front end creak, refurb, bent locking wheel key and another leak =(
    By nick-v2.2 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th February 2010, 19:58
