Thread: headlight fuse ?????
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default headlight fuse ?????
    hi my passenger headlight dont work checked bulb its working fine but wont work in headlight is there a fuse or relay.
    thanks dean
    Sunny Dartmoor
    Got to be a fuse,not got your manual???
    leicester
    Trim : Sri xp2
    Mileage : 100000
    cant find the book pack anywhere thought of that first thxs
    East Midlands
    Quote Originally Posted by deano1 View Post
    thanks dean
    Headlights do have a fuse ,its the fusebox in the engine compartment ,number f8 10 amp rating according to the wiring diagram.heated washer on same circuit ?if you have them do they work..?is the other headlight working ,if not then 99% fuse...more likely to be a bad connection in bulb holder..check all contacts and clean with abrasive paper...hope this helps.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    yes drivers light works fine
    East Midlands
    Time to get your sandpaper out then m8,give everthing a good clean...see what happens.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    cheers mate will go and have a look
    leicester
    Trim : Sri xp2
    Mileage : 100000
    after cleaning connections up and a bit of wd 40 its now working but my bulb warning light is still on checked all other lights seem to be ok.
    Surrey
    I think bulb warning comes on when high resistance. Clean the other side connection.
  1. Headlight adjustment fuse ?
    Last Post: 9th June 2010, 18:07
  2. Headlight Fuse
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2010, 16:55
  3. headlight fuse
    By penfold1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2009, 16:29
  4. Headlight washer system fuse keeps blowing
    By Matty H in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:58
  5. Headlight bulb fuse wattage?
    Last Post: 30th July 2007, 16:48
vectra c headlight fuse
vauxhall vectra headlight fuse
where is the headlight fuse on a 2008 vectra
vectra c headlight not workingvectra headlight fuse locationheadlamp fuse 2004 vectra2005 opel zafira front light fuse locationheadlight fuse vectra copel vectra c 2006 lights fusevectra headlights not workingpassenger main beam fuse vectra cvauxhall zafira headlight fusevectra c headlight fuse locationvauxhall vectra c headlight fuseheadlight relay vauxhall signumvauxhall vectra headlights not workingheadlamp fuse on a vectravauxhall insignia only 1 headlight worksvevtta c passenger side headlight fuse2008 vectra nearside headlight fusevectra nearside headlight fusevectra c passenger dipped beam fusewere the fuse for head light bulb vauxhall vectra czafira headlight fuse locationvectra c headlight fuse number
