Thread: Baxi Boiler problem
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Baxi Boiler problem
    Our boiler has started playing up. It is a Baxi, and I believe it is a 'Solo' model, power rating unknown.
    The other week I cured the heating issues by flushing and balancing the rads.
    Now the boiler has started to not work.
    On the front there is a removable panel, behind this panel is the temp control knob and some lights.
    In order, from left to right.
    overheat
    boiler on
    fan on
    pilot on
    burner on
    It doesn't get past the fan on light coming on.
    Normally the lights come on in order
    Boiler on
    fan on
    pilot on
    burner on
    Also, there doesn't seem to be any noise of the fan working from the discharge point (there certainly used to be)
    Any ideas? Is it the fan or controller?
    I am thinking more towards fan malfunction, as the fan on light illuminates, but the fan doesn't spin up, couple with it making a bit of a noise yesterday. A bit of a noise means a faint squeaking noise, as if the 'blades' were slightly catching the cowling.
    Tonight I am going to try to determine whether there is any power getting to the fan (hereby proving if the fan or PCB is at fault).
    Any advice to get to the fan assembly, or is it self explanatory once the main covers are removed?
    As it's not gas related I have no problem in attempting to find the fault.
    TIA
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    The outward extractor fan normally has to be running before the boiler will fire up, for obvious reasons. There will be a sensor in the airflow to detect whether its running or not. It definately wont work unless that fan is running.
    So I think your diagnosis assumptions are correct. Big question is... why is it not running? Sounds like you have the right idea's working your way back from the fan. May just be all bunged up with dirt etc.
    Mines a Worcester boiler, but my youngest son had a problem with his baxi last year and I recall him saying that there was a lot of info on the net including diagrams and parts etc. perhaps a search for the model of the boiler.
    Hope you sort matey, let us know what it turns out to be.
    Regular Member videodoctor's Avatar
    Blackpool
    Have you checked that the pressure gauge is above 1 bar to 1.5 bar?
    If its low then the boiler won't fire.
    As you bleed the rads then the pressure drops and you have to keep topping it up.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yep, that's something I'm doing too.
    I agree with the fact that until and unless the fan is working, the pilot will not light and hence burner will not fire. There has to be a sensor to detect fan operation, a pressure sensor. But without fan turning there will not be any air movement and hence not be detectable. So the boiler is functioning as designed - ie not working as fan inop.
    No pressure sensor for water, it's a normal boiler with storage tank, not a combi.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It's a Baxi Solo 3 50 PFL model.
    GC number 41 075 22
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    For completeness,
    Dismantled the thing last night.
    Found the fan to be a little stiff when turned by hand. The motor was kicking in but couldn't turn it.
    Me being me, and bidding to save money under the current financial climate, I thought I'd dismantle the fan assembly to determine why it was so stiff. The reason became very apparent when i removed the spindle bearing races. One bearing was almost stuck solid.
    I couple of drop of oil later and a bit of persuasion freed it up lovely.
    All back together and working fine.
    Fan looks like this one.
    I thought £165 for a new fan assembly was a bit steep, and I dare bet you can't buy the bearings separately.
    East Midlands
    Quote Originally Posted by Ste View Post
    For completeness,
    Alls well that ends well then ste..don't you just luv it when that happens,and a fair packet saved aswell ..so fair play to you.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Stick some grease in instead of oil as it will last longer. Oil will run off and you will be back at stage 1 again, not working!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Unfortunately, you have to make do with what you have to hand. The only thing I had was oil, so that is what got used. I didn't want to have the heating off another day, especially as the kids are not at school this week.
    If it goes again I will probably use something more permenant, but at 10:30pm you really don't have too many options.
  1. Any boiler engineers on here?
    By lee gsi in forum General Chat
    Last Post: 3rd February 2013, 20:48
  2. combi boiler problem ??
    By bembo449 in forum The 'Off Topic' room
    Last Post: 4th February 2012, 10:20
  3. Gas boiler broke? or is it?
    By spoons in forum General Chat
    Last Post: 22nd September 2010, 13:46
  4. combi boiler ?
    By rickeys16v in forum General Chat
    Last Post: 7th September 2010, 22:39
  5. Boiler specs
    By Ste in forum General Chat
    Last Post: 29th January 2009, 11:07
