Thread: 225/45/17's : What tyre pressure to run at?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default 225/45/17's : What tyre pressure to run at?
    Just hammered my wallet for 4 new tyres.
    I went from standard 215's up to 225/45/17's.
    For those who have made this very common switch to the new size/profile, what pressures do you recommend I run them at?.
    Thanks.
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    The tyre pressures are listed in the manual for 225's - with mine (1.8) the pressures were the same as the 215's, I don't know about the 3.0 diesel.
    Regular Member shan's Avatar
    I asked the same Q a couple of weeks ago and got mixed answer's. Average came out at 35 psi.
    Tyneside
    for 3.0V6 the book says
    front - 39psi (41 for full load)
    Rear - 35psi (48 for full load)
    Quote Originally Posted by mark1319 View Post
    With these presure's the ride is rock hard.
    Belfast
    You're likely running XL tyres, so the ride will be rock hard anyway. Pressure should be the same as the 215s.
  1. Tyre size for 17's
    By ROY GBIV in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 10:48
  2. tyre pressure
    By rave5 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2009, 11:48
  3. Tyre pressures for 215/50/17's on a 1.9 cdti 150 2005/05 please??
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2008, 19:27
  4. tyre pressure
    By dancam70 in forum Suspension, Wheels & Brakes
    Last Post: 11th March 2007, 19:33
  5. Tyre Question....225/45 17's ...
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2007, 13:16
tyre infatio on vectra c 2254517
what tyre pressure to be on a vectra a 2254517
