Thread: Springs look wrong
    middlesbrough
    Default Springs look wrong
    hi guys i own a vectra 2.0t facelift and think the front end looks high ive measured the gap between tyre and wheel arch and the front is 60mm and the rear is 30mm is this correct. am looking at dropping the front end and really need to know by how much. if i lower it by 30mm does this mean ill be left with a gap of 30mm up front and a 0mm gap at the rear as i want it to look reasonably ballanced.
    Sunny Dartmoor
    Most are like that mate,you can buy springs that lower it more at the front to the rear,can't remember the name though........
    Belfast
    Front is higher than the back on my 1.8 too, so seems pretty normal. Eibach Sportline drop 50 front and 30 rear.
    middlesbrough
    if i go for the eibach sportline will this cause problems with speed bumps and such
    Sunny Dartmoor
    No m8,should'nt have problem....
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i wouldnt measure the gap between the arches to judge difference in height as the arches are slightly different shapes anyway.
    the way i do it is to mearsure from the side skirt to the floor, once at the front of the side skirt and once at the rear. for me this gives me an idea if the car is level or not.
    middlesbrough
    would i have to change shocks if i went for the sportline
    Belfast
    You wouldn't have to, but it's recommended. Vectra shocks aren't the world's finest.
  1. Wrong springs yet passes MOT :S
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 14:19
  2. Urgent help... new coil springs wrong size
    Last Post: 9th June 2010, 22:41
  3. Urgent help...dealer fitted wrong springs..what to do??
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 08:29
  4. Are my coils springs wrong?
    By jonesy in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 21:07
