Results 1 to 10 of 11
Thread: mot faliure! on brakes please help
    hull, east yorkshire
    Default mot faliure! on brakes please help
    hi im new to vectra c, i have just bought a vauxhall signum 1,9 cdti 150 , very very nice car had beed looking at them a while, its on a 54 plate, had it mot'd other day and it failed on hand brake and on brakes, had new pads put it, but it failed on brake pedal sinking to floor if pressed down, been to garage to day they have had my car in and changed the pads and have give it a new brake fluid and bleed all brakes, they suggested a master cylinder may have gone, has any body else had these problems or had them repaired if so what is the damage for a master cylinder as they sound expensive lol, also the hand brake failed as to much travel , i have been told i will have to replace the handbrake as it will not tighted because of the self adjust system on it, thanks
    11 Post(s)
    When you wound the piston back into the rear caliper, did you slacken off the bleed nipple or just force brake fluid back up into the master cylinder?
    There is a risk of flipping the rubber seals in the master cylinder if you did the latter.
    Admin plasma's Avatar
    On the Forum
    321 Post(s)
    Engine : 150
    Mileage : 74000
    Brake pedal will travel down on these diesels, its known as diesel creep. Having new pads fitted will cause the pedal to feel spongy until the pads bed in probably, had loads of folks on here reporting the same problem. After driving for a couple of hundred miles pedal comes up and feels normal again.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    mine still have travel on the pedal, as i think there might be a bit of air in the system somewhere
    Regular Member benny's Avatar
    Feb 2006
    dudley
    exsesive pedal travel on a vec c is normal ...new pads make the symptom seem worse ..if they press the pedal slowly the pedal will go all the way to the floor ..if pressed quick the pedal will be very hard ....im shure there are notes on the mot system about this symptom on the vec c ....
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Pedal drops normally, do not think your garage knows what they are doing apart from getting more money from you. As for the hand brake travel, how many notches does it come up and I will compare it to mine?
    Sunny Dartmoor
    Quote Originally Posted by merikiito View Post
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Any news on this post?
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    I noticed the same on mine, i did the big brake upgrade and spent days trying to bleen air out of the system which there wasnt! and 3L of brake fluid, it took a trip to the stealers and for them to say its normal! aarrggh...
    I have Vec-C SRI diesel estate. brakes work fine but when you stop ,the pedal slowly goes to the floor!.. VX say this is standard on vec, sig's and vivaro vans.. tried a few at they offered.. it did! as they said so its nothing i found to worry about, albeit i did for two weeks, they have got better as the new pads and discs settle down, but it did worry me at first.
    hi i finally got new pads, and a handbrake cable, and a brake fluid change, personally i dont think i needed them but its passed its mot so happy with that now, brake is still the same , does go all the way to the floor, also a new handbrake cable and the handbrake stayes the same as before , looks like its just one of those things i was unsure about but seems a few of us have the same problem on the diesels.
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Gearbox & Clutch Faliure?!
    By mattster87 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 16:38
  3. brakes
    By panos9 in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 00:13
  4. mot faliure :(
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2009, 14:20
  5. my old brakes
    By aerodynamic18 in forum Northern Ireland (RO - Vacant)
    Last Post: 9th May 2008, 09:26
