Thread: Rear window wont go up
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Rear window wont go up
    Hi all, I have a 53 plate vectra Elite, From the drivers window control I can send rear drivers window down but it wont switch back up, I have to press the switch at the rear, all the other windows work fine from all locations,
    Also If i send windows down using key fob then let go all stop bar the faulty one which carrys on down to its stop, however the keyfob will send it back up.
    Any ideas on what it could be and or cost to repair it?
    Sunny Dartmoor
    I'd say faulty earth,have it checked by someone who know's about Electric's.......
    Regular Member Ian G's Avatar
    Merseyside
    Locate, unplug and re-seat the control boxes and all switches for a start. I'll nip in TIS in a bit and find them unless anyone else is able to assist.
    Ive unplugged both front and rear switches, and the multiplug that connects the door loom. still no joy this happend a week or so ago but then sorted itself the next day now its not been right for a few days, its damn annoying having to reach backwards if i select the wrong window DOH
    could the problem be the front switch?? I took it off and opened it up only to find is was only a PCB and nothing mechanical, is there anyone local to nottinghamshire who has a spare I could try and possibly buy if it is the problem
    Sunny Dartmoor
    Could be the switch,have you got any scrapyards locally??
    FIXED IT.
    First of all not impressed with vaxhaull,
    I had to work in temperatures like this;
    This was the problem, its a shock that this never shorted and torched the car, is it worth complaining to vauxhall about this the cars only 4 years old id expect this from a 20 year old car.
    Sunny Dartmoor
    That don't look good,result that you found it though top job......
    cheers mate and thanks to all sugestions from all, the worrying thing is the 2 smaller cables look a very clean break.
  1. Rear door wont open
    By fingers66 in forum Bodywork & Interior
    Last Post: 11th October 2011, 15:06
  2. VXR rear splitter on an SRi - Wont Fit?
    By vectraboyy in forum Styling
    Last Post: 5th November 2010, 11:50
  3. rear door wont open.
    By jun in forum Bodywork & Interior
    Last Post: 15th February 2009, 18:19
