Results 1 to 10 of 13
Thread: ultimate Styling Angel Eyes MOT nightmare!! Any help guys?
    Jan 2008
    Tyrone
    Default ultimate Styling Angel Eyes MOT nightmare!! Any help guys?
    Hello again peeps!
    The brother in law took the vec for an mot wash and to get headlights alligned this avo, only for the guy to go half crazy under the bonnet saying they can't be got right.. can't adjust these lights.. they're American or French or something!!
    Now, I had an idea my beam was wonky and never got round to alligning after they were fitted by the body shop a while back in the course of a few repairs.
    This leaves me ******ed as I am only home from work and been told this and test is at half 8 in th morn!
    Surely Ultimate styling wouldn't have given me a euro pair?
    Does anyone know if there is an adjuster for lhd/rhd on these. The brand name is Depo.
    I fitted a new motor in shortly after.. would the way in whicjh I inserted make any difference?
    Cheers!
    Nick :-0
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yes there was a thread yesterday i think highlighting the white plastic lever that need switching...i believe merikito posted the piccie...it will probibly mean taking the lights out ...ie dropping bumper to remove them
    are they saying beam is to high or facing the wrong way ?????????????
    Jan 2008
    Tyrone
    Apparently the muppet gave up saying they were not even going the right way and no way would they come right using the twiddly adjusters!
    Hopefully this is it and I can find the switch and rectify this tonight!
    I wouldn't have affected it by the way in which I inserted one of the motors a while back, would I?
    Cheers!
    Nick :-)
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    wouldn,t of thought so...i guess they have been wrong since install............i think most of the angeleyes come over here set up for euro driving...i had to change mine
    Belfast
    Goes to show most mechanics are idiots.
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    i have a plan.............just drive on the right and your lights will be ok
    Northampton
    Engine : A20DTH
    Mileage : 88000
    There should be a little lever of some sort. This pic shows a genuine VX Xenon Headlight (I so love saying I have Xenons) with a lever highlighted. Yours may not be the same but there will be something there. Depo headlights can be LHD or RHD as they are universel
    You should have had instructions with them explaining how to change them. They used to come with a label on as well.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You should be able to find the lever without taking the headlight off. It will be easier to take the air filter housing out and you will be able to look inside the headlight easier but I changed mine by putting my hand inside will they were in situ
    Northampton
    hey i had the same prob with my mot! But i managed to put them to rhd as they were on lhd! No need to take the light off! There is a switch/lever u full near the main beams! Sorts them out!
    Jan 2008
    Tyrone
    Update lads!!
    Well, there was certainly nothing resembling the very clear and well thought out lever on the oem lights!
    I found the little ****** away on the dipped beam enclosure.. basically a piece of coat hanger with a curled end! Was real awkward too because, when I went to drop the bumper for a good look see I saw the guy who done a few repairs and fitted a new bumper a while back decided it was too much bother getting the black vx push fasteners for where the bumper comes up to the front panel, so stuck a few dirty great metal rivets through the two!
    Finally figured out that it worked kinda like a safety pin to move it..ie: push it in a bit to release then move up or down til it catches in position for lhd or rhd
    The yellow instruction stickers were there, but I found them very unhelpful, and only really understood the line diagram after I had sussed what the setup was by meself, also (and I must just double check) the advised postion for lhd/rhd were in reality the other way around!
    Anyway, got it sorted, and a friend of a friend aligned them for me tonight with the right gear.. hope she passes the mot in the mornin now!
    So, if anyone with these depo, Ultimate Styling lights needs to adjust the directionality the lever is in on the side of the dipped beam metal casing and it will feel like a bit of coat hanger!
    Thanks!
    Nick :-)
  1. LED Angel Eyes
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2012, 08:14
  2. Angel eyes
    By pthres in forum Styling
    Last Post: 12th May 2012, 09:23
  3. Angel eyes
    By PAULMAC77 in forum Styling
    Last Post: 22nd December 2009, 18:36
  4. Angel Eyes
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2008, 11:19
  5. i did it my angel eyes
    By pipamish in forum Styling
    Last Post: 3rd March 2008, 22:14
