Thread: my smokin vectra
    luton
    confused my smokin vectra
    hi all just a quick question i have noticed over the last week that when i start my car there is quite a bit of white smoke coming out the back. it goes after about ten mins or so , and my car is running sweet no miss fire or anything like that so was wondering if anyone has had this or what it is please cause its quite worrying to be honest . cheers.
    Regular Member old cruiser's Avatar
    slough
    Are you sure it's no more, than condensation, as the ambient temperature has dropped quite a bit over the last week or so; warmth from exhaust into cold atmosphere hence white smoke.
    Cheers Pete
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    theres a big difference between condensation and smoke
    One is nothing to worry about, the other is
    Condensation is the stuff you get out a kettle, its very fine and wispy. Doesnt tend to smell or taste of anything either if you walk into it. Thats because its water
    Smoke on the other hand, usually means something is burning. If comming out of the exhaust usually oil. You can tell the difference as this is much quicker and hangs low and generally smells horrible.
    If its condensation (the same as you get comming out of a kettle) then its nothing to worry about and completely normal.
    luton
    it is quite whisppy but there is loads of it and it has a very slight smell to it, a bit petroly if that makes any sense. my mechanic mate said its just condensation but i no my car and it does look differant. he said change the plugs and air filter if im worried see if that helps.
    Tyneside
    It will smell like petrol as it's straight out of the cylinders.
    If it hangs in the air and builds up it's something to worry about, but if it's coming straight out the exhaust and quickly dispersing it's just condensation with the cold weather.
    Quote Originally Posted by lewrymyster View Post
    dont bother mate
    its just condensation.
    Every car does it during winter. And the petrol smell is the unburnt petrol you can smell. This is one of the reasons the vec engines idle higher when cold, as colder engines are most inefficient and dont burn the petrol. Thats why you can smell unburnt petrol in the exhaust fumes.
  1. smokin'
    By gomez in forum Engine & Drivetrain
    Last Post: 11th January 2013, 18:39
  2. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  3. Replies: 1
    Last Post: 28th February 2010, 14:54
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
  5. Smokin'.....
    By Penfold101 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2008, 21:46
