Results 1 to 10 of 18
Thread: Removal of the EGR valve via Tech2 or remap???
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Removal of the EGR valve via Tech2 or remap???
    Right been having a read through Total Vauxhall (page 20) and noticed that Regal say that by removing the EGR Valve (in the remap) it will keep the intake clean.
    So no future problems with the EGR valve then? As we know these cause problems.
    I assume that this can also be done to standard cars via Tech 2 and maybe it will save some money for someone whos has gone faulty.
    I have the BSR remap so I am going to ask them if they can do it/recommend it unless someone knows different???
    Northampton
    Engine : A20DTH
    Mileage : 88000
    bump
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Cant really add mate, but the EGR is easily disabled on the 2.2 petrol via Tech 2 or a home brew bit of wiring. There has been mention of the EGR disabled on the 1.9 oil burner. All I can remember is a dealer disabled one guys because they couldn't get hem a new one for some time.
    EVERYWHERE
    I recently blocked off the EGR intake on my V6 diesel Vectra,but this brought up an 'insufficient EGR flow' spanner light.But with a little experimentation I have now had no problems for months by reducing the intake hole size to about the size of a five pence piece where before it was larger than a fifty pence piece! There are others that have done this mod and so far have reported no ill effects.
    The benefits are better pick up (mixture is not contaminated by exhaust gases when you initially floor it),better warm up (higher combustion temps),better mpg (slightly),less soot (higher combustion temps = less soot particles),and less contaminants (soot particles) finding their way into the oil and therefore prolonging oil/engine life.
    The only downside is a slight increase in NOx which isn't tested for at an MOT anyway,whereas soot is.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    can this be done on the 2.2 dti if what hole do i make smaller
    Belfast
    It's a pain on the DTi, peadar. You can't just block the EGR due to the shape of it's opening on the inlet manafold. Believe me I tried with my 2.0DTi (uses the same design EGR).
    The easiest way is to block the channel through the head from the exhaust manafold, but it means pulling the exhaust manafold (or inlet manafold) and making up a custom gasket with the EGR channel blocked.
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Quote Originally Posted by diesel dog View Post
    I have been running mine with two 5.5mm holes in the blanking plate for a while and all OK. The point I am trying to find is the smallest hole without generating the "insufficient EGR flow" warning. Funnily enough, for me the jury is out on the improved MPG as mine appears to have fallen, however, I need to keep an eye on this for longer. The biggest plus for me though is the improved oil longevity, and the benefits this brings to the engine itself, and quicker pickup.
    If I could get the EGR Tech2'd out, especially if recommended by a reputable tuning company, then I would.
    Cheers,
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Emailed BSR Sweden and had the following reply:
    No BSR will not "remove" any function that are involved in emmision control
    Seems thats a "no" then! I now wish I had gone to Regal and got their remap which gives high BHP and a few other features not on the BSR remap.
    Live and learn, although I am not unghappy with my BSR remap but it would be nice to have got rid of the EGR Valve and the problems that can bring
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    So, from reading above posts:
    Is it possible to block off the EGR Valve on a 1.9 CDTi with the Regal Remap?
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I am running the EDS/Regal remap which has blocked the EGR and all seems well at the moment. I have a choice of 190bhp or 200bhp with no EGR or the same with EGR. The 190bhp setting has the highest torque which is what I like, damm quick acceleration
  1. Dpf, Egr removal software and remap group buy.
    By Desolation91 in forum Gauging Interest Threads
    Last Post: 11th March 2013, 20:13
  2. Not feeling Much difference after remap / DPF Removal
    By vectrasri150black in forum Engine & Drivetrain
    Last Post: 20th July 2012, 19:39
  3. DPF Removal, Performance Remap + Decat
    By StarDust2k5 in forum Engine & Drivetrain
    Last Post: 5th January 2012, 17:14
  4. CDTI 150 Remap + DPF Removal
    By adam_starkie in forum Engine & Drivetrain
    Last Post: 13th June 2011, 16:27
  5. I'm going for it...Remap & DPF removal here I come...
    By mattyc in forum Diesel Engine related
    Last Post: 19th May 2011, 14:22
tech 2 egr delete
tech2 programming egr
how to delete egr valve from 2.0 dti vectra c
vectra c 2.0dti egr do i need to program a new one
2.0 dti egr bypass
egr delete with tec 2
tech2 disable egr
vectra egr valve delete
remove dpf with tech 2
egr 2 0dti egr off
gm tech 2 turn off dpf and egr
z22se tuning software egr off
tech 2 egr options mgcomb
vectra c egr delete
disabling egr with tech2
2.0 dti egr removal tech 2
egr delete software vauxhall
https:www.vectra-c.comforumshowthread.php60830-Removal-of-the-EGR-valve-via-Tech2-or-remap
egr remap z22se
how to delete the egr valve on a vectra
y22dtr remap with tech2
dpf delete tech 2
jak wyłaczyć EGR tech2
vectra c egr removal
vauxhall vectra EGR remove software
