Thread: ??How 2 Change Crank Sensor 2.0DTI??
    Birmingham
    Default ??How 2 Change Crank Sensor 2.0DTI??
    Anyone know how to do this??...the difficulty level???...the location of it???
    thanks in advance
    West
    Can anyone confirm the location of the crank sensor?
    Can they be cleaned or just a replaced?
    Cheers!
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Think its just below the oil filter on front of engine
    Irmscher Insignia CDTI 130
    West
    Cheers!
    Birmingham
    I assume the engine is the same as a 2.2 DTI in a Vectra-B. If so, Don is right as I just changed mine on the B last month and its a pig to get to.
    Undertray off, car as high as possible on the axle stands and then try to sqeeze your hand in to get to the torx bolt. You have about a hand space of workable room, so be careful....my hands had scrapes and grazes all over.
    The wire on the B's sensor was connected to the top of the engine so you have to follow it up and then snip the cable ties.
    Good luck.
    Bye bye Vec B
    - Hello Siggy!
  1. Where is the crank sensor 1.9 cdti 8v
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 05:46
  2. Crank Sensor
    By GCusdin in forum Engine & Drivetrain
    Last Post: 13th December 2012, 12:13
  3. 2.0DTi Crank Pulley !!
    By Led in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 17:55
  4. 2003 2.0dti, Where does the crank position sensor read from?
    By Neil.b in forum Engine & Drivetrain
    Last Post: 5th January 2009, 20:16
  5. ??How 2 Change Crank Sensor 2.0DTI??
    By shatz in forum Engine & Drivetrain
    Last Post: 28th October 2008, 13:55
vectra c 2.0 dti crankshaft sensor
vectra senzor limited diesel dti 2.0
https:www.vectra-c.comforumshowthread.php60812-How-2-Change-Crank-Sensor-2-0DTI
vauxhall zafira 2.0 dti crankshaft sensor location
where is crankshaft position sensor located on vauxhall zafira dti
how to change crankshaft sensor on vectra a 2.0
vectra 2.0 dti crankshaft sensor location
how to replace zafira 2.0 dti crank sensor
were is crank sensor on a 2005 vectra diesel
vauxhall 2.0 DTi zafira crank shaft sensor
crankshaft sensor vectra 2.0 dti
2003 vauxhall zafira 2.0dti crank position sensor
opel vectra c 2.0dti crankshaft sensor problems
vauxhall zafira 2.0dti crankshaft sensor
vectra 2.2 dti crankshaft sensor
vauxhall vectra 2.0 dti 04 crankshaft sensor error
where is the crankshaft sensor on a vauxhall vectra c 04
where is crank shaft sensor located vauxhall vectra 2.0 dti 04
replace crankshaft sensor on 2009 vauxhall insignia 2.0 diesel
2ltr dti vectra crank sensor removel
vectra c 2.0 dti crankshaft sensor where is it
vectra 2 dti crank sensor change
vectra c diesel. 2.0 sensor
2.0dti crank sensor location
