Thread: 1.9cdti clutch problems
    derby
    Default 1.9cdti clutch problems
    Sometimes when the car is parked but the engine running it produces a rattling noise from the front left. At first i thought it was something lose checked all the plastic covers but nothing everything is tight. The other day when it happened i decided to de-press the clutch and the noise went and when i brough it back up the noise came back and could feel the pedal rattle slightly. The car has done 126000 miles prevoius service records do not show of any clutch change. Is this something serious or does it require an expert to look at or listen to being the case.
    May 2007
    Norway
    There is a bearing that spins when you release the clutch (press the clutch-pedal), and this bearing is probably defective. - I think this could be the cause of the sound/rattle in the pedal.
    To replace this, it is the same job as changing the clutch, so perhaps a good idea to overhaul the clutch as well when it is changed.
    London
    Hi !!
    I have same thing. And noises only when engine is cold !!
    I can hear rattling noise every time when engine is idling.
    Or I can really hear the clearly.
    But question is how danger it is for engine.
    What can happen in a future. Will this can be a big problem or not?
    derby
    my rattle seems to come and go as it pleases it's annoying because some days its realy loud other days nothing at all. Plus im supprised the front left drive shaft and wishbone aint been damaged yet with the amount of times my dad hits the pavement in a bid to get it into a parkin space. Is it with old age that people think its easier to just drive into the spot then swing out an reverse in cuz im sure its allot eaiser to reverse in which doesnt involve any mounting the pavement
    Oct 2009
    preston
    hi i think i have the exact same problem as yourself.
    there is a rattling noise coming from the engine near the passenger side. it comes and goes at different times. when it does come though, it remains present in idle and disappears when i press the clutch pedal all the way in.
    i have recently fitted the entire clutch kit but seem to be having a burning smell coming whn reversing but not driving normally, do you have the same problem? and can anybody please tell me what is going on and are the two problems related?
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    Have a look for DMF (dual mass flywheel) problems, will explain what the rattling is.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    derbyshire
    Do you have a how to to replace the clutch .Had a problem on a steep hill clutch slipped as i pulled away revs went high and started to smell .reversed down the hill slightley pulled away no problem been driving for a week now without any slippage clutch still has good bite any idea,s
    EVERYWHERE
    Quote Originally Posted by big john0 View Post
    Sometimes it's the friction clutch on the DMF that slips.
    DMFs have a built in friction clutch that is designed to prevent excess torque being put through the gearbox. You can get away with it maybe a couple of times before it eventually cries enough. Normally they don't slip unless other parts of the DMF are faulty or the car has been subject to "driver abuse" or "modification" as VX like to call it.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the dmf, bearings would only rattle when the clutch pedal pressed, but the DMF will rattle slightly all the time and especially noisy when the clutch is held at the biting point.
    Gazza4
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 05 1.9CDTI Sri (120) Clutch problems
    By Casey in forum Engine & Drivetrain
    Last Post: 27th November 2011, 12:24
  3. 1.9CDTI 150, LUK Clutch Kit
    By barkzz in forum Engine & Drivetrain
    Last Post: 9th June 2011, 08:54
  4. DMF / Clutch 1.9CDTi 150
    By tony-1977 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2011, 11:53
  5. 1.9CDTI Clutch Juddering
    By robdd1 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 21:00
vauxhall vectra 1.9cdti clutch problems
does vectra c clutch judder cause damage
