Thread: SRi 150 Cdti Clutch/Flywheel Going Gone..
    Wakefield
    Default SRi 150 Cdti Clutch/Flywheel Going Gone..
    Hi all,
    Just had the Timing belt kit changed on the Vectra, (64K 55 Reg Facelift) old one wasn't that bad, didn't change the water pump, everything thing looks ok on that side..
    NOW!!! The clutch is bad, you can hear it rattling and it struggles to pull on the motorway yesterday, when you set off in 1st it makes all sorts of squeaks and noises.
    Took it to VX Wakefield when the millage was 52K and dealers did say clutch is slipping bad, but it's not covered under warranty, i asked him to get in touch with VX Head quarters, but no avail.
    Anyone can help if it should have been done under warranty? or have any of you had yours replaced under warranty? its got 64K now and it is expensive to buy never mind fitting costs.
    Help me...!!! what can i do???
    Full Member Big Sig's Avatar
    Depends if its the clutch that has worn out - would not be covered - or the DMF that has failed - may be covered.
    May 2007
    West Yorkshire
    I had my flywheel, master cylinder replaced at Evans Halshaw Wakefield last week. Facelift with a couple of months left of warranty 40k, all similar sounding to yours. Done under warranty, otherwise I was told it would have been quite costly.
    Wakefield
    Well just spoken to VX Headquarters and was told that case has been logged and that the car needs to go in to VX Wakey for them to remove gearbox and check it out, if the fault is present then they will pay, otherwise i will end up paying for it
    So advice, should i book it in and get it checked and PRAY that it gets done under warranty?
    or just buy a clutch and fly wheel replace it?
    What are the chances of VX paying for this, or finding a fault?
    May 2007
    West Yorkshire
    I would ask to speak to the service manager and stress nicely that if the work is under warranty then EH can do it, otherwise you will take it away for repair, It's their call and at the end of the day they either make cash under the VX warranty or a little from you for diagnostics. It does sound like the DMF. Just as a side note EH wfd are poor to say the least in my opinion.
    Wakefield
    well i rang the dealers and got the price for a clutch kit, flywheel and slave cylinder, which is comes to £800 inc VAT.
    Manage to contact another place called Auto Vaux, who buy the original parts direct from suppliers and total quoate was £543 inc VAT
    so am thinking that i might just buy it and get it installed rather than argue with the dealers and them turning round and saying its not going to be covered under warranty.. what you think?
    Wakefield
    Quote Originally Posted by sshooie View Post
    yep they sure are..
    They will have to take the box out to fit a new clutch anyway so why not just let them do it? maybe tell them if it needs doing and isn't covered you will supply the parts?
    Wakefield
    Update 04/11/08 :
    Car went into VX dealers yesterday and they have confirmed the flywheel was looooooose! They are just doing the various checks and measurement which are going to be reported to VX headquarters.
    Fingers crossed.
  1. 1.9 CDTi solid flywheel / clutch
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 19:58
  2. Replies: 0
    Last Post: 25th September 2012, 13:44
  3. New flywheel and clutch :(
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 16:20
  4. cdti dual mass flywheel and clutch
    By andy.l in forum Parts for sale
    Last Post: 14th June 2009, 18:57
  5. 1.9 Cdti Flywheel/clutch Problems
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 20th October 2007, 16:00
