Thread: gearbox bearings
    staffs
    Default gearbox bearings
    as my 1st post will say hello to you all so HELLO
    ive just got a 2l 16v ls vectra, with bout 89000 miles cheap.... the fella i got it off said before i started it up they was a bearing problem that will need replacing int he next 3 -6months or so..
    started it up, and the engine seems normal but they was a small noise when in netruel, once in gear or with the clutch down it goes away, it doesnt affect the car at all.. but he did say it will need changing.
    any idears in the stoke/crewe area that i can get it sorted? also will it need a full gearbox and any ideas what will the cost be??
    like i say the car is sound, only bit of rust i can see is near the boot lock, other than that it seems sound..
    Full Member Big Sig's Avatar
    Sounds like the clutch release bearing.
    East Midlands
    Hi and wellcome to the site..not at all wishing to scaremonger but a rattle or whine coming from gearbox in neutral usually means the lay shafts are on there way out,so could mean a gearbox swap.
    East Midlands
    if it was the realease bearing the noise can be heard when clutch pedal depressed.
    Quote Originally Posted by macdad View Post
    Hmmm you could have a point there
    staffs
    so any idea how much a gear box swap will cost including a new box?
    Yorkshire
    It could still be the release bearing try putting some pressure pressure on the clutch pedal and see if it goes. If it does it sounds like the release bearing.
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    mine is the same, its a little noisy out of gear with the clutch up but pressed it down and the light rattle goes, iv only done 63,000 but it works fine! id like to know how much this would cost to fix also, so please enlighten us both?!
    staffs
    a mate i rang today said it sould be the clutch bearing and im sure he said they were bout £20 maybe?? then fitting..
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    So it will be more like £220 with fitting :P
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Top Mount Bearings
    By wotsthestory in forum General Motoring Chat
    Last Post: 17th May 2012, 19:22
  3. Front bearings gone??
    By merikiito in forum Suspension, Wheels & Brakes
    Last Post: 18th May 2011, 09:18
  4. wheel bearings
    By scottietlr in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 17:34
